Bug Report
Bug Report
Postby yarbo » Wed Jun 13, 2012 7:25 pm
Tried to manage my shared media, and got the following error:
Exception   java.lang.NullPointerException
Message   null
Java version   Sun Microsystems Inc. 1.6.0_20
Operating system   Linux 2.6.35-32-generic-pae
Server   jetty-6.1.x
Memory   Used 102 of 145 MB
Stack trace   java.lang.NullPointerException
   at net.sourceforge.subsonic.controller.ShareSettingsController.getShareInfos(ShareSettingsController.java:110)
   at net.sourceforge.subsonic.controller.ShareSettingsController.handleRequestInternal(ShareSettingsController.java:63)
yarbo
Re: Bug Report
Postby ajkessel » Fri Jun 22, 2012 8:11 pm
Same issue here.
ajkessel
Re: Bug Report
Postby BKKKPewsey » Sat Jun 23, 2012 12:05 am
And the SS version is? :?
Re: Bug Report
Postby yarbo » Sat Jun 23, 2012 3:02 am
Oh. Thought it would have been in the error report. I am using 4.7 beta 2
yarbo
Re: Bug Report
Postby ajkessel » Sat Jun 23, 2012 11:43 am
Same here, latest Beta.
ajkessel
Re: Bug Report
Postby BKKKPewsey » Sat Jun 23, 2012 12:08 pm
ajkessel is your java version the same? or at least 1.6.xx rather then 1.7.xx
Might help Sindre to track it down (although I think he's got his hands rather full at the moment :roll: )
Re: Bug Report
Postby ajkessel » Sat Jun 23, 2012 12:16 pm
1.6.0_26
ajkessel
Re: Bug Report
Postby yarbo » Sat Jun 23, 2012 6:53 pm
Should I update Java? Also worth noting that I am running this on Ubuntu.
yarbo
Re: Bug Report
Postby ajkessel » Sat Jun 23, 2012 10:32 pm
Upgraded to 1.7.0_05. Same result.
ajkessel
Re: Bug Report
Postby GJ51 » Sat Jun 23, 2012 10:40 pm
There is a programming error that has been identified and will be corrected in the next release. If you uninstall EVERYTHING and start with a clean install of the latest Java and then install 4.7b2 it should work, it lease it has for me on both a standard Windows install and a WAR install on Tomcat.
Others have reproted that if you delete the "work" directory or the Jetty cache, depending on you installation type, it also fixes the problem.
Either way, all should be healed soon.
Re: Bug Report
Postby ajkessel » Sun Jun 24, 2012 6:58 pm
Which directory would I delete on a Linux install? I don't see work/cache?
ajkessel
Re: Bug Report
Postby BKKKPewsey » Sun Jun 24, 2012 7:06 pm
ajkessel wrote:Which directory would I delete on a Linux install? I don't see work/cache?
subsonic\jetty\xxxx\jsp\org\delete whats here
Re: Bug Report
Postby ajkessel » Sun Jun 24, 2012 7:26 pm
I just tried that (under 'org' was 'apache'); no luck. Same error after deleting and restarting subsonic.
ajkessel
Re: Bug Report
Postby scharnhorst » Sat Sep 08, 2012 2:59 pm
Hello
Same issue on my side even with 4.7Beta 3.
scharnhorst
