[2012-06-15 22:52:12,787] INFO PlaylistInputStream - ethan listening to "Movies\The.Sunset.Limited.2011.720p.Bluray.X264.Hive-CM8.mkv"
[2012-06-15 22:52:12,790] DEBUG TranscodeInputStream - Starting transcoder: [c:\subsonic\transcode\ffmpeg] [-ss] [0] [-i] [\\WALTERNATE-PC\Movies\The.Sunset.Limited.2011.720p.Bluray.X264.Hive-CM8.mkv] [-async] [1] [-b] [1000k] [-s] [320x240] [-ar] [44100] [-ac] [2] [-v] [0] [-f] [mp4] [-vcodec] [libx264] [-strict] [experimental] [-preset] [superfast] [-threads] [0] [-]
[2012-06-15 22:52:12,842] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) ffmpeg version N-31653-gfaa3381, Copyright (c) 2000-2011 the FFmpeg developers
[2012-06-15 22:52:12,842] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) built on Jul 28 2011 01:57:12 with gcc 4.6.1
[2012-06-15 22:52:12,842] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) configuration: --enable-gpl --enable-version3 --enable-memalign-hack --enable-runtime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
[2012-06-15 22:52:12,842] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) libavutil 51. 11. 0 / 51. 11. 0
[2012-06-15 22:52:12,842] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) libavcodec 53. 9. 0 / 53. 9. 0
[2012-06-15 22:52:12,842] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) libavformat 53. 6. 0 / 53. 6. 0
[2012-06-15 22:52:12,842] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) libavdevice 53. 2. 0 / 53. 2. 0
[2012-06-15 22:52:12,842] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) libavfilter 2. 27. 3 / 2. 27. 3
[2012-06-15 22:52:12,842] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) libswscale 2. 0. 0 / 2. 0. 0
[2012-06-15 22:52:12,842] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) libpostproc 51. 2. 0 / 51. 2. 0
[2012-06-15 22:52:12,842] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) [matroska,webm @ 01B1D1A0] Estimating duration from bitrate, this may be inaccurate
[2012-06-15 22:52:12,842] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Input #0, matroska,webm, from '\\WALTERNATE-PC\Movies\The.Sunset.Limited.2011.720p.Bluray.X264.Hive-CM8.mkv':
[2012-06-15 22:52:12,842] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Duration: 01:30:52.86, start: 0.000000, bitrate: 384 kb/s
[2012-06-15 22:52:12,842] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Stream #0.0(eng): Video: h264 (High), yuv420p, 1280x704 [PAR 407:400 DAR 37:20], PAR 237:233 DAR 4740:2563, 23.98 fps, 23.98 tbr, 1k tbn, 47.95 tbc
[2012-06-15 22:52:12,842] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Stream #0.1(eng): Audio: ac3, 48000 Hz, 5.1, s16, 384 kb/s (default) (forced)
[2012-06-15 22:52:12,842] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) [buffer @ 02064EC0] w:1280 h:704 pixfmt:yuv420p tb:1/1000000 sar:237/233 sws_param:
[2012-06-15 22:52:12,842] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) [scale @ 02364960] w:1280 h:704 fmt:yuv420p -> w:320 h:240 fmt:yuv420p flags:0x4
[2012-06-15 22:52:12,842] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) [libx264 @ 01B1FB40] using SAR=237/233
[2012-06-15 22:52:12,842] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) [libx264 @ 01B1FB40] using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2
[2012-06-15 22:52:12,842] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) [libx264 @ 01B1FB40] profile High, level 2.0
[2012-06-15 22:52:12,842] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) [libx264 @ 01B1FB40] 264 - core 116 r2037 f8ebd4a - H.264/MPEG-4 AVC codec - Copyleft 2003-2011 - http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x3:0x3 me=dia subme=1 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=16 chroma_me=1 trellis=0 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=6 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=250 keyint_min=23 scenecut=40 intra_refresh=0 rc=abr mbtree=0 bitrate=1000 ratetol=1.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1.40 pb_ratio=1.30 aq=1:1.00
[2012-06-15 22:52:12,842] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) [mp4 @ 01FA3A40] muxer does not support non seekable output
[2012-06-15 22:52:12,842] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Output #0, mp4, to 'pipe:':
[2012-06-15 22:52:12,842] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Metadata:
[2012-06-15 22:52:12,843] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) encoder : Lavf53.6.0
[2012-06-15 22:52:12,843] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Stream #0.0(eng): Video: libx264, yuv420p, 320x240 [PAR 237:233 DAR 316:233], q=2-31, 1000 kb/s, 90k tbn, 23.98 tbc
[2012-06-15 22:52:12,843] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Stream #0.1(eng): Audio: aac, 44100 Hz, 2 channels, s16, 64 kb/s (default) (forced)
[2012-06-15 22:52:12,843] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Stream mapping:
[2012-06-15 22:52:12,843] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Stream #0.0 -> #0.0
[2012-06-15 22:52:12,843] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Stream #0.1 -> #0.1
[2012-06-15 22:52:12,843] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) Could not write header for output file #0 (incorrect codec parameters ?)C:\subsonic\transcode>ffmpeg -ss 0 -i \\WALTERNATE-PC\Movies\The.Sunset.Limited.
2011.720p.Bluray.X264.Hive-CM8.mkv -async 1 -b 1000k -s 320x240 -ar 44100 -ac 2
-v 0 -f mp4 -vcodec libx264 -strict experimental -preset superfast -threads 0 st
reamorwhat
[matroska,webm @ 019FD160] Estimating duration from bitrate, this may be inaccur
ate
[buffer @ 019FFF20] w:1280 h:704 pixfmt:yuv420p tb:1/1000000 sar:237/233 sws_par
am:
[scale @ 0384AFC0] w:1280 h:704 fmt:yuv420p -> w:320 h:240 fmt:yuv420p flags:0x4
[libx264 @ 03568B20] using SAR=237/233
[libx264 @ 03568B20] using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE
4.2
[libx264 @ 03568B20] profile High, level 2.0
[libx264 @ 03568B20] 264 - core 116 r2037 f8ebd4a - H.264/MPEG-4 AVC codec - Cop
Output #0, mp4, to 'streamorwhat':
Metadata:
, q=2-31, 1000 kb/s, 24k tbn, 23.98 tbc
forced)
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Press [q] to stop, [?] for help
Input stream #0.1 frame changed from rate:48000 fmt:s16 ch:6 to rate:48000 fmt:s
16 ch:2
GJ51 wrote:I don't know what the problem is, but you can just turn off transcoding and view an MP4 directly in JW Player. MP4 and FLV are the native formats for JW.
GJ51 wrote:What platform are you on? I have all my video files transcoding fine on Wimdows, but I use a release of ffmpeg that I have found works very well with Video for me. I renamed it "Videoffmpeg" and use that on the video transcode line. If you're on Windows I can send you the download link.
On the standard install I did experience problems with avi videos.
GJ51 wrote:No all my videos are transcoding to flv except for mp4's which are just sent directly to JW.
I may have played with trying to use ffmpeg to output to mp4 once or twice, but no success.
[2012-06-15 22:52:12,842] DEBUG InputStreamReaderThread - (c:\subsonic\transcode\ffmpeg) [mp4 @ 01FA3A40] muxer does not support non seekable outputUsers browsing this forum: No registered users and 44 guests
