Subsonic 4.7.beta2 Playlist
Postby lveill1 » Fri Jun 15, 2012 10:44 pm
I upgraded to Subsonic 4.7.beta 2 and no longer can access my playlists. Any help will be much appreciated. Thanks!
lveill1
Re: Subsonic 4.7.beta2 Playlist
Postby BKKKPewsey » Fri Jun 15, 2012 11:01 pm
You have to import the old playlists into SS. (one at a time)
However I couldn't get it to import my old 4.6 playlists :(
Postby lveill1 » Fri Jun 15, 2012 11:19 pm
Thanks for the information, I don't know where my subsonic playlists were saved. They don't appear to be in the subsonic folder on my C drive. A warning about this would have been nice, I certainly would not have upgraded.
lveill1
Postby BKKKPewsey » Sat Jun 16, 2012 12:42 am
They haven't been deleted - they are still in the same folder that you set up in 4.6
That would normally be in your media folders - not usually in the c:\subsonic folder
Postby nohart » Fri Jul 13, 2012 4:00 am
I upgraded to this beta version and had to go back because the beta would not import my original playlist. It only imported 1 but no more and when I created one I have no idea where it went. Plus when I accessed subsonic by android phone it said there wasn't any playlists. So these features are not implemented or they are broken.
nohart
Postby lveill1 » Fri Jul 13, 2012 12:20 pm
I was able to locate my playlist files & import most, but not all, of them. Thanks for the advice BKK.
lveill1
Users browsing this forum: No registered users and 35 guests
