wma not working
wma not working
Postby pac » Tue Jun 19, 2012 1:02 pm
Hello there.
I am unable to listen to my wma files in my music library.
I have managed to set up all the relevant components on my android phone and pc to access my music folder on the synology nas ds212+. I am only able to listen to the few mp3 tracks that I have.... Most of my albums have been saved as wma files and I am unable to access them through subsonic on both my pc or android device.
Please help
Pac
Mod: Moved post to correct section
pac
Re: wma not working
Postby BKKKPewsey » Tue Jun 19, 2012 2:58 pm
pac wrote:Please help
So why did you post in the tutorials section?
First read viewtopic.php?f=2&t=5506
Re: wma not working
Postby pac » Tue Jun 19, 2012 7:41 pm
:)......My first ever post ....many appologies
It does feel like I'm losing my mind though trying to get my head around this whole networking malarky !!! I'll get by with a little help from some freinds :)
pac
Re: wma not working
Postby GJ51 » Wed Jun 20, 2012 3:25 am
If you're having trouble with the networking part, just wait till you get to the transcoding part!
You say you can't access you wma files. Do you mean that you can see them but they won't play or that the folders they're in just don't show up in the music display in the left column?
OS and installation type are very helpful if you provide them.
Re: wma not working
Postby pac » Wed Jun 20, 2012 9:51 am
Os - Windows 7 - Installation type unsure ??
I am able to see all my folders on both pc and android device therefore the accessing the folders bit is done and operational.
When I come to play the track it simply doesn't play....mp3 works fine, but wma will not transcode ( if that is the correect terminology :)) ! )
Many Thanks
pac
Re: wma not working
Postby GJ51 » Wed Jun 20, 2012 3:15 pm
OK - try this.
Download this file and place it in "C:\subsonic\transcode"
https://skydrive.live.com/redir?resid=A ... 0A32A0!233
This file is just a different version of ffmpeg that has been renamed "Audiffmpeg"
Once the file is in the directory go to "Settings/Network"
The first entry is the mp3 audio line. Just change it to read : Audioffmpeg -i %s -ab %bk -v 0 -f mp3 -
This just instructs Subsonic to use the new version of ffmpeg to do the transcode.
Let me know if this fixes it for you.
Cheers.
Re: wma not working
Postby pac » Wed Jun 20, 2012 10:04 pm
Still not working :(
pac
Re: wma not working
Postby GJ51 » Wed Jun 20, 2012 10:18 pm
Can you send me a link over PM to a file that isn't working? Also, have you modified the transcoding string at all?
Re: wma not working
Postby pac » Wed Jun 20, 2012 10:44 pm
I have modified the transcoding string as instructed.
What does send me a link over Pm mean ??
pac
Re: wma not working
Postby BKKKPewsey » Wed Jun 20, 2012 10:50 pm
Personal Message
Re: wma not working
Postby pac » Wed Jun 20, 2012 10:54 pm
Ok ... 2 stupid comments in the same thread... Im never gonna get there !!!
pac
Re: wma not working
Postby pac » Wed Jun 20, 2012 11:09 pm
Let me see if I can be a bit more technical at this late stage of the day ....
It would seem the problem lies in the 1152 kpbs wma > mp3 conversion if that is of help ??
pac
Re: wma not working
Postby GJ51 » Thu Jun 21, 2012 12:26 am
My bad. I wanted you to send me a known bad wma file to see what it did on my system. We usually do this by using dropbox or skydrive to dump a file into a public share that can be downloaded by someone else. Once the file is in your public drive you generate a link to it that you can send to the other party so that they can download the file.
This was how I sent "Audioffmpeg.exe" to you.
Your PM said you fixed the problem. Glad to hear it. Let us know if you need anything else.
Cheers.
Re: wma not working
Postby pac » Thu Jun 21, 2012 8:30 am
Hello again ,
Problem is still un-resolved.
Android phone still refusing to play all wma files in all my albums.
Sample album link attached
https://www.dropbox.com/sh/of4l4wq53hk0 ... ANMKE/2Pac
pac
Re: wma not working
Postby GJ51 » Thu Jun 21, 2012 2:50 pm
I just tested the files you sent and they are not playing on my system either, but they do play in VLC. They might require a different transcoding setup, perhaps going back to first transcoding to wav and then using lame to transcode to mp3.
Are there any possible DRM issues here?
