No Connection When On 4G LTE
Postby Sp4rxx » Tue Jun 19, 2012 3:33 pm
I use my wifi @ work to stream from my server @ home to my Droid RAZR - not a problem. When I switch back to 4G, after 4 connection attempts, I get the following:
Error:
A network error occurred. Please check the server address or try again later.
I verify both through the name.subsonice.org address and the direct IP that the "Connection is OK" from the application's test button. I have checked the settings from the server side and I am not sure what to look for as far as a possible limit or denial on mobile usage.
Granted, the simple answer is to just use the wifi, but they are starting to audit wifi connections at work and I would like to switch it back to using my data on 4G LTE.
Sp4rxx
Re: No Connection When On 4G LTE
Postby BKKKPewsey » Tue Jun 19, 2012 5:06 pm
Have you tried to connect to the demo site?
That would determine if it's a server or phone issue.
Postby Sp4rxx » Tue Jun 19, 2012 11:17 pm
I was unable to locate the documentation as to what that demo address is - I keep finding mention of it all over the forum, but no actual address; and stupid me, I deleted it out of my Android App (or at least it's not listed).
Sp4rxx
Postby BKKKPewsey » Wed Jun 20, 2012 1:21 am
I expect you passed it on the way here :roll: http://www.subsonic.org/pages/demo.jsp
