ffmpeg mp3 downsampling problem [Resolved]
Postby omer33 » Wed Jun 20, 2012 8:30 am
I'm using the new 4.7-beta2 version on an feral hosting debian (no root access)
I left the downsampling command as the default: ffmpeg -i %s -ab %bk -v 0 -f mp3 -
The problem is when I try to downsample an mp3 (320) to a lower bitrate (128/96):
DEBUG   TranscodeInputStream   Starting transcoder: [/../subsonic/transcode/ffmpeg] [-i] [/../music/Arcade Fire/The Suburbs/Ready To Start.mp3] [-ab] [160k] [-v] [0] [-f] [mp3] [-]
DEBUG   InputStreamReaderThread   (/../subsonic/transcode/ffmpeg) FFmpeg version SVN-r0.5.6-4:0.5.6-3, Copyright (c) 2000-2009 Fabrice Bellard, et al.
DEBUG   InputStreamReaderThread   (/../subsonic/transcode/ffmpeg) configuration: --extra-version=4:0.5.6-3 --prefix=/usr --enable-avfilter --enable-avfilter-lavf --enable-vdpau --enable-bzlib --enable-libdirac --enable-libgsm --enable-libopenjpeg --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-pthreads --enable-zlib --disable-stripping --disable-vhook --enable-runtime-cpudetect --enable-gpl --enable-postproc --enable-swscale --enable-x11grab --enable-libfaad --enable-libdc1394 --enable-shared --disable-static
DEBUG   InputStreamReaderThread   (/../subsonic/transcode/ffmpeg) libavutil 49.15. 0 / 49.15. 0
DEBUG   InputStreamReaderThread   (/../ffmpeg) libavcodec 52.20. 1 / 52.20. 1
DEBUG   InputStreamReaderThread   (/../subsonic/transcode/ffmpeg) libavformat 52.31. 0 / 52.31. 0
DEBUG   InputStreamReaderThread   (/../subsonic/transcode/ffmpeg) libavdevice 52. 1. 0 / 52. 1. 0
DEBUG   InputStreamReaderThread   (/../subsonic/transcode/ffmpeg) libavfilter 0. 4. 0 / 0. 4. 0
DEBUG   InputStreamReaderThread   (/../subsonic/transcode/ffmpeg) libswscale 0. 7. 1 / 0. 7. 1
DEBUG   InputStreamReaderThread   (/../subsonic/transcode/ffmpeg) libpostproc 51. 2. 0 / 51. 2. 0
DEBUG   InputStreamReaderThread   (/../subsonic/transcode/ffmpeg) built on Dec 31 2011 16:14:46, gcc: 4.4.5
DEBUG   InputStreamReaderThread   (/../subsonic/transcode/ffmpeg) Input #0, mp3, from '/../music/Arcade Fire/The Suburbs/Ready To Start.mp3':
DEBUG   InputStreamReaderThread   (/../subsonic/transcode/ffmpeg) Duration: 00:03:20.95, start: 0.000000, bitrate: 320 kb/s
DEBUG   InputStreamReaderThread   (/../subsonic/transcode/ffmpeg) Stream #0.0: Audio: mp3, 48000 Hz, stereo, s16, 320 kb/s
DEBUG   InputStreamReaderThread   (/../subsonic/transcode/ffmpeg) Stream mapping:
DEBUG   InputStreamReaderThread   (/../subsonic/transcode/ffmpeg) Stream #0.0 -> #0.0
DEBUG   InputStreamReaderThread   (/../subsonic/transcode/ffmpeg) Unsupported codec for output stream
Can anyone please help?
omer33
Re: ffmpeg mp3 downsampling problem
Postby BKKKPewsey » Wed Jun 20, 2012 10:03 am
Does any transcoding work?
Try to play a non mp3 or video (non flv)
Postby omer33 » Wed Jun 20, 2012 11:46 am
I've tried transcoding from wma and m4a to mp3,
I get the same message
omer33
Postby omer33 » Fri Jun 22, 2012 7:30 am
omer33
Postby BKKKPewsey » Fri Jun 22, 2012 11:29 am
If you can access the transcode directory see if you can install a later static build ffmpeg there.
But as a windows user that's all I can suggest :|
Postby omer33 » Sun Jun 24, 2012 1:59 pm
Adding a new static build solved the problem!
Link to the static version I used: http://dl.dropbox.com/u/24633983/ffmpeg/index.html
Thank you!
omer33
Re: ffmpeg mp3 downsampling problem [Resolved]
Postby rezsbc » Mon Sep 17, 2012 4:56 pm
Thanks for posting this solution! Been having a couple of transcoding issues, tunes not playing, occasional audio glitches and this solved it for me!!
rezsbc
Users browsing this forum: Bing [Bot] and 22 guests
