Moving all music to new disk/s!
Postby PeeGee » Tue Nov 13, 2007 1:27 pm
Hi Sindre,
I know you and I talked about this before, but I thought it was worth bringing up again.
I recently had to move my whole musiccollection to a bigger disc, since the old one became to small. The sad part about this is that features like "Most frequently played" or "Most recently played" are now blank, there is no information/stats left.
Is there a way to fix this, or do I have to live with the fact of losing this information everytime I need to move the music?
Thanks / Patrik
PeeGee
Postby sindre_mehus » Tue Nov 13, 2007 2:28 pm
Hi Patrik,
There is a way around it :-) In Subsonic 3.2 I added an undocumented database query page where you can run SQL statements.
Please take a backup of the subsonic directory before doing this!
Log in as admin and go to http://localhost/subsonic/db.view
To look at the music_file_info table, run this query:
select * from music_file_info
Then you must do some SQL string manipulation to change the paths. For instance, if the location has changed from f: to g:, you would have to do the following update:
update music_file_info
set path = concat('g', substr(path, 2))
where path like 'f:%'
Good luck!
Postby PeeGee » Tue Nov 13, 2007 3:22 pm
Wow Sindre, SQL-possibility sounds great! :D
I will try this later, thanks Sindre!
/ Patrik
PeeGee
Users browsing this forum: No registered users and 70 guests
