Repeated Error 503 and 4.7b2
Postby mystery666 » Sat Jun 23, 2012 7:35 pm
I have a bigger issue of a system crashing and rebooting because of a RAID controller, but that will be fixed soon and i can deal with my music server randomly rebooting every few days.
Problem is, every time the system restarts Subsonic 4.7b2 does this:
HTTP ERROR: 503
SERVICE_UNAVAILABLE
RequestURI=/index.view
Powered by jetty://
This was never an issue with 4.6. I have to login, stop the service, clear Jetty, start service again. I've tried scripts to clear jetty on boot, and other things which seemed to cause other issues. is this a problem with Subsonic or something effecting Subsonic on startup?
Here is the log:
[2012-06-23 12:06:18,750] INFO DaoHelper - Checking database schema.
[2012-06-23 12:06:24,890] INFO Schema25 - Database table 'version' not found.  Creating it.
[2012-06-23 12:06:25,343] ERROR DaoHelper - Failed to initialize database.
org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is java.sql.SQLException: File input/output error c:\subsonic/db/subsonic.backup java.io.FileNotFoundException: c:\subsonic\db\subsonic.data (The process cannot access the file because it is being used by another process)
   at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:382)
   at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:429)
   at net.sourceforge.subsonic.dao.schema.Schema25.execute(Schema25.java:36)
   at net.sourceforge.subsonic.dao.DaoHelper.checkDatabase(DaoHelper.java:110)
   at net.sourceforge.subsonic.dao.DaoHelper.<init>(DaoHelper.java:67)
   at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
   at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
   at java.lang.reflect.Constructor.newInstance(Unknown Source)
   at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
   at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1245)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1010)
   at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472)
   at org.mortbay.jetty.handler.ContextHandler.startContext(ContextHandler.java:530)
   at org.mortbay.jetty.servlet.Context.startContext(Context.java:135)
   at org.mortbay.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1218)
   at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.deployWebApp(SubsonicDeployer.java:131)
   at net.sourceforge.subsonic.booter.deployer.SubsonicDeployer.<init>(SubsonicDeployer.java:65)
   at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
   at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
   at java.lang.reflect.Method.invoke(Unknown Source)
   at com.exe4j.runtime.LauncherEngine.launch(Unknown Source)
   at com.exe4j.runtime.WinLauncher$2.run(Unknown Source)
Caused by: java.sql.SQLException: File input/output error c:\subsonic/db/subsonic.backup java.io.FileNotFoundException: c:\subsonic\db\subsonic.data (The process cannot access the file because it is being used by another process)
   at java.sql.DriverManager.getConnection(Unknown Source)
   ... 82 more
[2012-06-23 12:06:31,515] INFO VersionService - Resolved local Subsonic version to: 4.7.beta2
mystery666
Re: Repeated Error 503 and 4.7b2
Postby mystery666 » Thu Jul 05, 2012 6:12 pm
I ended up reverting back to 4.6 do to the lack of playlists in the beta and I'm still having issues with 503 errors after rebooting.
Any ideas on how to get subsonic to properly construct the cache after a reboot?
mystery666
Postby BKKKPewsey » Thu Jul 05, 2012 9:12 pm
The problem appears to be due to the server "crashing" and therefore not releasing the files correctly.
I have no idea how you can get round that problem apart from stating the obvious eg stop it crashing.
If you started SS via a script you could delete the subsonic.lck file prior to starting SS which might stop that error showing.
However IMHO that is like using a small plaster on a severed limb :(
