Apple Lossless Playback - Subsonic 4.7b2
Postby timmyj » Fri Jun 29, 2012 9:13 am
Recently started playing around with Subsonic and have it working quite well (on a microserver running solaris 11). A significant portion of my library is encoded in Apple Lossless (e.g. dled in FLAC but converted so as to maintain compatibility with iPhone/iPod) I can't get playback to work of these particular files through the web player. They are all VBR around ~1000kbps.
It encodes successfully, I tried from command line and it works fine, and the web player loads the file duration correctly but when I click play nothing happens, there is also nothing in the logs to suggest any errors have been returned from ffmpeg.
Any thoughts?
timmyj
Re: Apple Lossless Playback - Subsonic 4.7b2
Postby BKKKPewsey » Fri Jun 29, 2012 9:28 am
What version of ffmpeg are you using? Is it the one that comes bundled with SS?
This seems very similar to the problems I got with wma lossless using the latest zeronoe build.
See viewtopic.php?f=2&t=9751
Jukebox worked fine but no sound using webplayer :?
Postby timmyj » Fri Jun 29, 2012 10:00 am
ive built it from latest source snapshot
using these flags
./configure --disable-ssse3 --enable-libfaac --enable-nonfree --enable-libmp3lame --enable-gpl --enable-version3 --enable-postproc --enable-x11grab --enable-libx264 --enable-libvorbis --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libtheora --enable-libxvid --enable-librtmp --extra-cflags=-I/opt/csw/include --extra-ldflags=-L/opt/csw/lib
timmyj
