Subsonic not working on other networks
Postby jackspoonv » Sun Jul 01, 2012 3:11 am
Though subsonic is a great thing to enjoy, I have been having a big problem trying to access the "home" server using another network besides the wifi in my own home (in which case it works perfectly).
The specifications are as follows:
Subsonic Agent installed on: Windows XP
Application used: Android Subsonic App
(pasted from "About" section): Version 4.7.beta2 (build 3012) – June 9, 2012
Server jetty-6.1.x, java 1.7.0_05, Windows XP (52.0 MB / 67.8 MB)
On any other network I happen to use (also with data traffic) I get the message "Contacting server, please wait" and almost immediately after, "A network error occurred. Retrying..."
I tried whatever came to mind, searched for answers on the subsonic forums, consulted the "getting started" section and I could not figure it out.
Any help would be appreciated
jackspoonv
Re: Subsonic not working on other networks
Postby BKKKPewsey » Sun Jul 01, 2012 10:58 am
jackspoonv wrote: searched for answers on the subsonic forums, consulted the "getting started" section
Hmm! not particularly well it seems :?
Read http://monroeworld.com/android/subsonic/ (documentation) especially the bit about setting up the router.
If you can access SS from within your LAN but not from outside then its the port forwarding in the router that's the problem.
Postby GJ51 » Sun Jul 01, 2012 2:54 pm
viewtopic.php?f=6&t=4867
I've always thought that the Tutorial section should be the first forum listing on the board. I don't think many new users actually read it until someone else directs them there. :wink:
Postby jackspoonv » Sun Jul 01, 2012 5:56 pm
Thanks for your prompt replies!
I have busting my brain to make it work for about 4-5 hours now, and I have kept a log of all I did
1.entered http://monroeworld.com/android/subsonic/
2.went over the "welcome", "introduction..."
3.set up server
4.installed server
5.configured server - changed port number to 8080
6.set admin password
7.configured folders
8.skipped permissions to remote folders - not needed
9.configured users
10.configured networks - "access your server over the internet" - box checked, "automatic configuration" - box unchecked, status: port forwarding disabled
11.misc configuration
12.tested the server locally - worked like a charm
13.obtained subsonic PC IP/MAC address
14.put subsonic PC on static IP - tried "Port Forward Setup Static IP address" program, status (in program: address is currently static)
15.set port forwarding - logged into router (after calling my internet provider for password and id), found "port forwarding"
-created new forwarding entry that looks like this:
service name: WWW
WAN interface: WAN1/ptm0.35
Server IP Address: 192.168.1.150 (taken from IPCONFIG /ALL under IP section)
External Port: start 8080 end 8080
Internal Port: start 8080 end 8080
Protocol: TCP/UDP
saved setting, enabled
16.testing the router - entering "http://lightmusic.subsonic.org" (set up much earlier in subsonic.org, which worked before on home wi-fi) - getting "unable to connect" from browser
-entering just "lightmusic.subsonic.org" - getting HTTP status 500 error message
17.going back to port forwarding (in case that would be the problem) - adding another forward entry with only differences being:
service name: FTP (could not give the same name as the other one)
internal port: start 80 end 80
18.testing the router - entering "http://lightmusic.subsonic.org" - getting HTTP status 500 error message
19.removing last forward entry - same result (HTTP 500 error)
20.going back to port forwarding - adding another forward entry with only differences being:
service name
and
external port: start 80 end 80
- getting message "since port 80 is used, the DSL router WEB server port in WAN side will be moved to 8080"
21.testing the router - HTTP 500 error
22.going back to setting static IP address in router menu - setting as follows:
IP address - 192.168.1.155
subnet mask - 255.255.255.0 (noted from IPCONFIG)
gateway IP address - 192.168.1.1 (also noted from IPCONFIG)
23. the internet connection drops :( - IP config shows IP as before configuration of router settings with IP 192.168.1.150
24.going back to instructions (the second reply on the forum)
25.Reaching "A complete guide to setting up subsonic (win/android)"
26.downloading "simple port forwarding" program - does not have my router model in its list
27.canyouseeme.org - IP:105.102.57.10, port:8080 - "success! can see service"
28.testing in browser with IP 192.168.1.150:8080 - goes to subsonic login (as it should)
Conclusion: I have no idea what I'm doing wrong or even if I am actually doing something good (I'm new to all this)
In the end, it still works on "home" wifi (same router) from the android app and substream on iphone but only if in the server section I write "192.168.1.150:8080"
It does not work on 3g (tested on two phones using subsonic android app and substream on iphone) - in the android app I'm getting the "contacting server..." and almost immediately "a network error ocurred, retrying..." and on iphone it just loads forever
I can't test it on another network right now as I don't have access to another one (seriously considering asking the neighbors for their password :D )
Whatever steps I have gotten wrong, I am willing to correct them as I've found that I developed a little obsession with making this work.
If patience with this is at hand, please indulge my lack of experience and receive plentiful thank yous :)
jackspoonv
Postby BKKKPewsey » Sun Jul 01, 2012 6:07 pm
You wont be able to test at the moment as the SS redirect service is down
Postby jackspoonv » Mon Jul 02, 2012 8:19 am
Does that mean what I think it means? :shock: so I might have made it work, but I won't know for sure until it's up again. Does anybody have any info on when?
Thanks a lot :D
jackspoonv
Postby BKKKPewsey » Mon Jul 02, 2012 11:42 am
It's working ok now :)
If the canyousee.org test is showing the port open you are either there or nearly.
