Redirect Service HTTP Status 500 error
Postby Rico » Sun Jul 01, 2012 4:12 pm
Subsonic has been working just fine. I made no changes to my server or network. Then all of a sudden I get this HTTP Status 500 error when I use my http://***.subsonic.org address. I can't access from outside my network. I can still enter in the numerical ip and access the server when I'm on the server computer itself. Any thoughts? Here's what I get:
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
org.springframework.web.util.NestedServletException: Handler processing failed; nested exception is java.lang.NoClassDefFoundError: org/hsqldb/jdbc/Util
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:924)
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:807)
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
javax.servlet.http.HttpServlet.service(HttpServlet.java:627)
javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
root cause
org.hsqldb.jdbc.jdbcConnection.<init>(Unknown Source)
org.hsqldb.jdbcDriver.getConnection(Unknown Source)
org.hsqldb.jdbcDriver.connect(Unknown Source)
java.sql.DriverManager.getConnection(DriverManager.java:582)
java.sql.DriverManager.getConnection(DriverManager.java:154)
org.springframework.jdbc.datasource.DriverManagerDataSource.getConnectionFromDriverManager(DriverManagerDataSource.java:174)
org.springframework.jdbc.datasource.DriverManagerDataSource.getConnectionFromDriver(DriverManagerDataSource.java:165)
org.springframework.jdbc.datasource.AbstractDriverBasedDataSource.getConnectionFromDriver(AbstractDriverBasedDataSource.java:149)
org.springframework.jdbc.datasource.AbstractDriverBasedDataSource.getConnection(AbstractDriverBasedDataSource.java:119)
org.springframework.jdbc.datasource.DataSourceUtils.doGetConnection(DataSourceUtils.java:113)
org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:79)
org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:577)
org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:641)
org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:670)
org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:678)
org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:710)
net.sourceforge.subsonic.backend.dao.AbstractDao.query(AbstractDao.java:41)
net.sourceforge.subsonic.backend.dao.AbstractDao.queryOne(AbstractDao.java:45)
net.sourceforge.subsonic.backend.dao.RedirectionDao.getRedirection(RedirectionDao.java:32)
net.sourceforge.subsonic.backend.controller.RedirectionController.handleRequest(RedirectionController.java:57)
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:875)
note The full stack trace of the root cause is available in the Apache Tomcat/5.5.33 logs.
Rico
Re: HTTP Status 500 error
Postby jmunchies1 » Sun Jul 01, 2012 4:19 pm
It's not your setup, it's down for me as well.
Whatever server subsonic uses, I guess some type of DNS, for the domain names is down.
jmunchies1
Postby Rico » Sun Jul 01, 2012 4:26 pm
Thanks, Munch Man. Just saved me a lot of aggravation.
Rico
Postby frozensteel » Sun Jul 01, 2012 4:31 pm
I have just received my license a few minutes ago and while registering, I got an HTTP Status 500 error at first. Now all I'm getting is "Failed to test web address. Internal Server Error (HttpResponseException)" Is the server down? Any ETA when it's coming back up?
frozensteel
Postby Rico » Sun Jul 01, 2012 4:39 pm
You just have really bad timing, Frozensteel. Subsonic seems to be experiencing some (very uncharacteristic) problems right now. You might want to check back into the forum to make sure this is resolved before you proceed.
BTW, Subsonic is normally very reliable. Don't let this glitch discourage you.
Rico
Postby savestheday » Sun Jul 01, 2012 4:40 pm
Guys in the meantime you can setup a dyndns address and just make sure you append :4040 to the end. Your router has to forward 4040 (or whatever outward port you want) of course. This is working for me.
savestheday
Postby Rico » Sun Jul 01, 2012 4:48 pm
Works for me on my local network, savestheday, but my friend can't get it to work on his remote computer even with the dyndns. And I can't get it to work on my phone app.
Rico
Postby frozensteel » Sun Jul 01, 2012 4:53 pm
Rico wrote:You just have really bad timing, Frozensteel. Subsonic seems to be experiencing some (very uncharacteristic) problems right now. You might want to check back into the forum to make sure this is resolved before you proceed.
Its not discouraging me at all. I've been using this product through its trial period and its the best out there (I use it with the iSub application for the iPhone). I used Qualcomms Skifta before trying this application and its garbage, so I am very thankful that this program is available. I just have a family vacation that goes on the road tomorrow for 13 hours and need some music so its not that much of a drag. Just making sure its not me and wondering when its going to come back up.
frozensteel
Postby Rico » Sun Jul 01, 2012 4:57 pm
I hear ya, frozensteel. I guess we're all wondering the same thing. This will make a lot of people's Sunday a real drag with no Subsonic phone app. It would be nice to hear something official, but I'll grant that the problem just cropped up rather recently for that.
Rico
Postby toecephus » Sun Jul 01, 2012 5:16 pm
Same error for me, hopefully we'll see fixed soon
toecephus
Postby BKKKPewsey » Sun Jul 01, 2012 5:21 pm
Its a new feature that Sindre is testing for 4.7 - It gives the users new types of fault logs to post in the forum :roll:
Its to stop you from getting bored :lol:
ps I emailed Sindre to let him know
Re: Redirect Service HTTP Status 500 error
Postby Ivanslav1 » Sun Jul 01, 2012 5:40 pm
I got this same error on 4.7 beta after running great for the last week. Loved 4.7, but I think I should go back to 4.6 until this is fixed.
Ivanslav1
Postby BKKKPewsey » Sun Jul 01, 2012 6:14 pm
Ivanslav1 wrote:Loved 4.7, but I think I should go back to 4.6 until this is fixed
Err! best of luck with that. :?
IT IS THE REDIRECT SERVICE WHICH IS DOWN
So yourname.subsonic.org will NOT work until it is fixed - even the demo server is down.
See viewtopic.php?f=2&t=9819#p43091
Postby alphawave7 » Sun Jul 01, 2012 7:22 pm
Status: Failed to test web address. Connect to subsonic.org/66.49.215.227:80 timed out (ConnectTimeoutException)
My log shows WARN 'Failure to Register Web Address' at 9:27am Pacific, and again at 11:29am..suggesting it passed at 7:27am.
Oddly, my IP:port is also not working...now to find out why... :roll:
Postby jontramos » Sun Jul 01, 2012 7:26 pm
Any progress on the redirect service? I would love to get an update.
jontramos
