[SOLVED]CPU Usage ?
[SOLVED]CPU Usage ?
Postby Abraxus » Mon Jul 02, 2012 1:35 pm
Hello !
I actually using Subsonic on a dedicated server based on Debian.
But since a few days, it seems that java use lots of CPU (between 50 et 70 %). Is it normal ?
Is there any solution to bring the CPU usage of java and subsonic to less than 50 % ?
Abraxus
Re: CPU Usage ?
Postby Gomez » Mon Jul 02, 2012 1:49 pm
i noticed that too.
Subsonic is eating all my CPU, some days ago there was no problem. Havent found the answer...
I am on Debian 6 x64. Subsonic 4.6
Gomez
Re: CPU Usage ?
Postby Abraxus » Mon Jul 02, 2012 2:09 pm
I'm on the same distrib as you.
On my "top" i got :
Cpu(s): 34.2%us, 64.7%sy,
Perhaps there is an upgrade of java recently ... I cant remember
I'm on 4.6 and i try the 4.7 beta 2 and no change.
Which version of java do you use ?
abraxus@dagobah:~$ java -version
java version "1.6.0_18"
OpenJDK Runtime Environment (IcedTea6 1.8.13) (6b18-1.8.13-0+squeeze1)
OpenJDK 64-Bit Server VM (build 14.0-b16, mixed mode)
abraxus@dagobah:~$
Abraxus
Re: CPU Usage ?
Postby Gomez » Mon Jul 02, 2012 4:58 pm
I have exact the same java version.
No, i do not think there was an java update.
My top seems the same:
"Cpu(s): 32.7%us, 66.2%sy,"
Some1 else with the problem?
Maybe the Leap Secound bug? :P
http://it.slashdot.org/story/12/06/30/2 ... tems-ready
Gomez
Re: CPU Usage ?
Postby Abraxus » Mon Jul 02, 2012 5:02 pm
Oh god i just found another link about it !
But there is several process .Which is the good one ? :/
EDIT : ok this is what i do :
/etc/init.d/ntp stop
date `date +"%m%d%H%M%C%y.%S"`
And then :
Cpu(s): 13.6%us,  2.6%sy,
:D
Source
Abraxus
Re: [SOLVED]CPU Usage ?
Postby Gomez » Tue Jul 03, 2012 5:24 am
thanks, now all cool again :)
Gomez
Users browsing this forum: No registered users and 41 guests
