Saving to PlaylistFolder in 4.7b2
Postby amels802 » Mon Jul 02, 2012 7:24 pm
In 4.6, I was able to create playlists in the web UI and they automatically saved to the PlaylistFolder specified in the subsonic.properties file. Even though this file is still present in 4.7b2, it appears this can no longer be done that way. I assume it's because of the difference in how the data is maintained. Are there any workarounds other than exporting and moving manually?
I understand from this post that I have to import the playlists into the new version.
viewtopic.php?f=2&t=9723&hilit=no+saved+playlists
amels802
Re: Saving to PlaylistFolder in 4.7b2
Postby BKKKPewsey » Tue Jul 03, 2012 12:55 pm
4.7 final will have auto-import playlist feature so I assume the playlist folder will then come back into play.
Postby bushman4 » Tue Jul 03, 2012 1:11 pm
Actually, I disagree. I believe that Sindre has moved to storing the playlists in the database by user, so the Playlist folder may be used as an "import from" location, but I would not expect any kind of automated export of the database playlists to file-based playlists.
I may be wrong, but that's what it looks like to me.
That doesn't mean that, with a little scripting or fancy db.view work, that you couldn't get the playlists into the format you desire, but I don't think that cross-application use of the playlists was in Sindre's mind when he re-did the playlist feature to handle multiple users...
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby BKKKPewsey » Tue Jul 03, 2012 1:28 pm
Sorry didn't pick up on the exporting bit.
I assume that 4.7 final will auto-import from a designated folder eg the playlist folder.
But there is no mention of any export playlist function in the TODO list (that I can see)
Postby amels802 » Tue Jul 03, 2012 1:30 pm
Thanks, I didn't specify cross-application use of the playlists but that's actually the reason. While I'm listening to music at work with Subsonic, I'll usually add songs to a playlist for listening later. I have a few Squeezeboxes for whole-home audio (like others here) that also pick up on these playlists.
amels802
