Subsonic on my Web space?
Postby splash1 » Wed Jul 04, 2012 8:48 am
Hello Together
Ok, so my question is, can i setup the subsonic server on my web space?
my server, hostet by "hostsar.ch" includes follow services:
SSL-Zertifikate
PHP4 + PHP5
MySQL
PERL
XML
CronJobs
SSI
Mod-rewrite (.htaccess) Support
Php-ini Support
Own CGI-BIN directory
FrontPage 2002/XP
and some other functions..
so is it possible to install my own subsonoic server directly on this webserver, which is configured with my own domain name!?
regards
Splash
splash1
Re: Subsonic on my Web space?
Postby diffy » Thu Jul 05, 2012 7:55 am
No, you need a host that offers Apache/Java support. Subsonic does not run on Apache/PHP, it is simply not the same architechture.
You'll need a VPS with a proper login shell so that you can install the right packages,
or just use a webhost that supports it out of the box.
There are thousands of companies offering that out there. Just keep a close tab on your bandwidth allowance.
I believe the Subsonic website has two "officially endorsed" hosts. Take a look at them:
http://www.subsonic.org/pages/hosting.jsp
diffy
