Unable to login outside of my network
Postby zoolander » Fri Jul 06, 2012 1:35 am
Problem Description: I am unable to access subsonic using my hostname http://zoolander.subsonic.org or the isub iPhone app.
On a PC the error is: Cannot open Page
On iSub the error is: Server Unavailable, Error code 8
Troubleshooting Steps: I have verified with the vendor that the Untangle Firewall and Portforwarding settings I have are correctly configured. They have been able to successfully telnet to my host and they have verified that the portforwarding is correctly configured. The Firewall logs show an incoming connection from the iPhone and that the connection is allowed to pass.
Playback Application and version: IE, FF, iSub
Subsonic Version: 4.6 (build 2583) – December 6, 2011
Server Version: jetty-6.1.x, java 1.6.0_31, Windows 7 (50.8 MB / 96.7 MB)
Hardware Platform: Windows
Java Memory Limit: 100 MB
Problem Filename: All Files
Output from ffmpeg -i: N/A
Last ten log file lines:
[7/5/12 3:00:23 AM MST] INFO SearchService Created search index with 77000 entries.
[7/5/12 3:00:23 AM MST] INFO SearchService Created search index with 78000 entries.
[7/5/12 3:00:24 AM MST] INFO SearchService Created search index with 79000 entries.
[7/5/12 3:00:24 AM MST] INFO SearchService Created search index with 80000 entries.
[7/5/12 3:00:24 AM MST] INFO SearchService Created search index with 81000 entries.
[7/5/12 3:00:25 AM MST] INFO SearchService Created search index with 82000 entries.
[7/5/12 3:00:25 AM MST] INFO SearchService Created search index with 83000 entries.
[7/5/12 3:00:25 AM MST] INFO SearchService Created search index with 84000 entries.
[7/5/12 4:33:32 PM MST] INFO PodcastService Starting scheduled Podcast refresh.
[7/5/12 4:33:32 PM MST] INFO PodcastService Completed scheduled Podcast refresh.
zoolander
Re: Unable to login outside of my network
Postby BKKKPewsey » Fri Jul 06, 2012 1:53 am
What ports are you using?
Postby zoolander » Fri Jul 06, 2012 2:01 am
8083
4040
zoolander
Postby BKKKPewsey » Fri Jul 06, 2012 2:25 am
Have you checked with http://canyouseeme.org that those ports are open on your router.
I would suggest turning of the ssl port and get a connection on http first.
Postby zoolander » Fri Jul 06, 2012 2:38 am
I disabled ssl, and verified ports using the site you suggested.
8083 - Open and I'm able to connect with iSub now over 4g
4040 - Connection Refused,is this port needed on a Windows system?
Why did disabling ssl make it work all of the sudden? My subsonic server is the only thing using 443?
zoolander
Postby GJ51 » Fri Jul 06, 2012 7:39 am
443 wasn't open.
Users browsing this forum: Bing [Bot] and 25 guests
