How to display Subsonic in a frames page
Postby Prem » Fri Nov 23, 2007 1:00 pm
I access much applications through a certain web application, and use HTML frames pages or inline frames.
Subsonic maximizes itself to 'full page' login screen when displayed in a frame, what can I do with the source code in order to display Subsinoic inside a frame?
Prem
Prem
Postby sindre_mehus » Sat Nov 24, 2007 8:14 am
Hi Prem,
The relevant code is in login.jsp:
<script type="text/javascript">
        if (window != window.top) {
            top.location.href = location.href;
    </script>
You could try to modify this according to your needs.
Hope this helps,
Postby Prem » Thu Dec 27, 2007 8:20 pm
Yes, thank you Sindre, that worked.
I just deleted the whole section.
Prem
Postby stebbi67 » Fri Jan 25, 2008 9:27 am
I have played with this code :
    </script>
In this file : /apache-tomcat-5.5.25/webapps/subsonic/WEB-INF/jsp/login.jsp
back and forward. I have removed it like Prem did but still no luck.
If the frame name is "main" how would I modify the script?
Stebbi67
stebbi67
