Network Shares on 4.7 Beta 1/2
Postby MattPal » Mon Jul 09, 2012 4:03 am
I'm having a problem with my files showing up in the 4.7 Beta 1/2 versions.
My media files are stored on a NAS (Thecus N5200) in various folders which I have mapped into Subsonic. Subsonic is running on my main PC, which has access to the server/files with no issue.
I recently upgraded to 4.7 Beta 2, and though file scans appear to work, they never show up in interface. After finding the issue in Beta 2, I downgraded to Beta 1 and had the same problem. However, when I downgraded to 4.6, everything showed up and worked as expected.
Is there currently an issue in the Beta versions for network shares?
MattPal
Re: Network Shares on 4.7 Beta 1/2
Postby BKKKPewsey » Mon Jul 09, 2012 10:58 am
MattPal wrote:Is there currently an issue in the Beta versions for network shares?
Not as far as I am aware - you did hit the refresh view in the left side after scanning was finished?
I am accessing my media over the network on my test server (SS4.7b2) np
However you may be affected by a related problem - see viewtopic.php?f=4&t=9686&start=90#p42764.
The temp fix for that from Sindre is further down that thread.
Postby MattPal » Mon Jul 09, 2012 11:48 pm
Yep - sounds like the same issue that you linked - I'll just sit tight until the next beta version. Thanks! 8)
MattPal
Users browsing this forum: No registered users and 41 guests
