I'm getting "No media folders found." Linux server W7 client
Postby stevekinga » Mon Jul 09, 2012 7:52 pm
I am running Subsonic 4.6 on Fedora 16 linux 32-bit, all Fedora updates installed as of last week. My client is an up-to-date (that is, all windows updates applied) 64-bit Windows 7 Ultimate.
In /var/sysconfig/subsonic, the contents are:
SUBSONIC_ARGS="--https-port=4040 --port=0 --max-memory=150"
The client browsers are both IE 9 and Firefox 13.0.1.
The problem is that I get "No media folders found" when I try to use subsonic from W7. When I use it from the linux box or other linux boxes (even port-forwarded from other sites), it works fine. I looked in the subsonic logs and couldn't find anything there that showed a problem.
I'm not sure it matters, since I only allow access via the https port, but I have squid 3.2.0.16-1 on the server, running in "intercept" mode. Again, it works fine for all other traffic to the W7 box, so I don't think it's that.
I'm at a loss.
stevekinga
Re: I'm getting "No media folders found." Linux server W7 cl
Postby BKKKPewsey » Mon Jul 09, 2012 8:47 pm
As "No media found" is generated by the server, how can it work accessing from a linux client and not a windows client :?
Both are accessing (or should be) the same server and will receive and see the same results.
And what do you mean by "client" - the client in your case is simply a web browser.
Postby stevekinga » Mon Jul 09, 2012 9:17 pm
Yes, the client machine is W7 and the client app is a browser. When I go to settings, it shows the right directory. Maybe it has something to do with differences in java?
stevekinga
Postby BKKKPewsey » Mon Jul 09, 2012 9:41 pm
No the java version on the client is irrelevant - if you can see your media on one browser you will see it on all.
Have a look at your original post and re-read - its possible (very likely in fact) that there is some confusion here.
It is impossible for SS to show info eg your music to one browser and not another.
(IE8 being the exception :lol: )
Are you sure you have only one instance of SS running?
ps and before anybody questions what I have just written - yes I know it is possible but not in this case.
Postby stevekinga » Mon Jul 09, 2012 9:58 pm
Only 1 instance of subsonic is running (verified via ps). To be specific, I can see the folders in 3 linux boxes: the one with subsonic as the server, one on the same lan, and 1 on a separate lan tunneled in. They all run the linux version of firefox 13.0.1.
Both IE 9 and Firefox 13.0.1 on the W7 Ultimate box don't work. However, I tried it on another W7 Ultimate box similarly configured and it worked. I'll reboot the problem machine and try again.
stevekinga
Postby stevekinga » Mon Jul 09, 2012 10:14 pm
I rebooted, and it's even more weird. It still gets the error message, but also now lists the music. Lest you think I'm nuts, I'm attaching a screenshot of the IE window.
And when I try to play a song, I get this error:
Exception
java.lang.SecurityException
Message
Access denied to file /mnt/Music/Pink Floyd
Java version
Sun Microsystems Inc. 1.6.0_24
Operating system
Linux 3.4.2-1.fc16.i686.PAE
Server
jetty-6.1.x
Memory
Used 29 of 60 MB
Stack trace
java.lang.SecurityException: Access denied to file /mnt/Music/Pink Floyd
at net.sourceforge.subsonic.service.MusicFileService.getMusicFile(MusicFileService.java:68)
at net.sourceforge.subsonic.service.MusicFileService.getMusicFile(MusicFileService.java:85)
at net.sourceforge.subsonic.controller.MainController.handleRequestInternal(MainController.java:72)
at org.mortbay.jetty.bio.SocketConnector$Connection.run(SocketConnector.java:227)
at org.mortbay.jetty.security.SslSocketConnector$SslConnection.run(SslSocketConnector.java:626)
stevekinga
Postby BKKKPewsey » Mon Jul 09, 2012 10:50 pm
Congratulations You Have Won the Prize
It would appear that you have managed to achieve the impossible :lol:
I really do not understand what is going on there. :?
With regard to "No media found" message have you cleared the browser cache as it may be remembering that.
With regard to java error - no idea :(
I will be as fascinated, as I am sure you will be, to find out
Postby GJ51 » Mon Jul 09, 2012 11:29 pm
Interesting problem whose solution eludes me as well.
Closely related, I installed the WAR version of SS on my MS Server 2012 RC test box and had everything up and running just dandy. Today I logged on and it can't read any of the media folders. I don't get any Java errors; it just won't read the folders. Undoubtedly a permissions issue, but I can't think of anything that I changed since last week that would have caused the problem. the Tomcat service has my logon credentials and should be able to access anything on the entire network.
Very strange indeed.
Postby stevekinga » Tue Jul 10, 2012 4:34 am
The cache was a big part of it. I cleared the IE and FF caches and IE now works. FF now shows "No media folders found", but no folders are present like before. So, there must of been some stale cache items confusing both IE and FF, but now IE works but FF doesn't.
stevekinga
Postby GJ51 » Tue Jul 10, 2012 7:18 am
Mine turned out to be a dns issue - all fixed.
Postby stevekinga » Fri Jul 13, 2012 5:00 pm
I removed my firefox profile and started a new one. What a pain after years of tabs, add-ons. Anyway, subsonic works again.
stevekinga
