WIFI problem
WIFI problem
Postby medapayne » Sat Jul 14, 2012 3:27 pm
Hello I manage to connect to ethernet Subsonic from anywhere but impossible for me to connect to wifi I do not understand could you explain to me how to do.
Should we adjust something in my router?
If so what are the ports for the wifi to redirect.
I confess I do not understand could you explain all this.
Thank you in advance.
medapayne
Re: WIFI problem
Postby alphawave7 » Sat Jul 14, 2012 3:41 pm
Here's the basic but thorough guide..should make no difference whether you're accessing via wifi or ethernet, if you are properly networked.
http://monroeworld.com/android/subsonic/
If you can access shares on the computer running Subsonic over wifi, you should be good to go.
Re: WIFI problem
Postby medapayne » Sat Jul 14, 2012 5:44 pm
I try but nothing in WIFI i don't understand.
I have a iPhone with iSub music streamer application when i open this a message said " Streaming 3G/EDGE may require opening ports on your home router" or " You may be connected to WIFI but do not have acces to the outside internet"
Can you explain me please?
Ethernet or Wifi is a different connection to access Subsonic?
My test: ethernet local: OK
ethernet outside: OK
wifi local: OK
wifi outside: not OK why?
thank's by advance
medapayne
Re: WIFI problem
Postby alphawave7 » Sun Jul 15, 2012 3:03 am
medapayne wrote:I try but nothing in WIFI i don't understand.
wifi local: OK
thank's by advance
The guide I posted prior has the directions to ensure your subsonic.org address is properly forwarded, and if you can access files remotely, it should already be working whether the connection is wifi OR ethernet or 3G/EDGE. How you connect isn't important..THAT you can connect (port forward) is what is important.
Re: WIFI problem
Postby medapayne » Sun Jul 15, 2012 8:58 am
How working "port forward" website?
I don't understand.
Thank's
medapayne
Re: WIFI problem
Postby alphawave7 » Mon Jul 16, 2012 2:24 am
medapayne wrote:How working "port forward" website?
I don't understand.
Thank's
It is covered in the guide I posted..see 'Configure Server'.
