404 - File or directory not found - When uploading zip file
Postby domenicfz » Sun Jul 15, 2012 11:58 pm
I have successfully installed Subsonic using Tomcat and IIS. Everything works perfect except when I tried to upload a zip file remotely (using www.mydomain.com). It throws the following error (which I am sure is an IIS error)
Server Error
404 - File or directory not found.
The resource you are looking for might have been removed, had its name changed, or is temporarily unavailable.
However, it works just fine when logged in to the server on my home network (localhost)
I apologize if this is posted somewhere but I have yet to find it. Thanks in advance to any help/direction to a fix on this.
domenicfz
Re: 404 - File or directory not found - When uploading zip f
Postby kroustiba » Wed Jul 25, 2012 5:54 pm
same for me
kroustiba
