Download the installation package and run it. This installs Subsonic.app in Applications. Start it by opening Applications and click the Subsonic icon. A small headset icon will appear in the menu bar. If you want Subsonic to start automatically when you log in, open System Preferences > Accounts and add Subsonic to the list of Login Items.
After installing and starting Subsonic, open the Subsonic web page on http://localhost:4040.
Advanced configuration
To change the port number, Java memory settings or other startup parameters, edit /Applications/Subsonic.app/Contents/Info.plist.
Troubleshooting
If Subsonic doesn't start properly you can troubleshoot it by starting it from the command line: /Applications/Subsonic.app/Contents/MacOS/JavaApplicationStub.
Also check the logs in /Library/Application Support/Subsonic.
