Big Problem [SOLVED]
Postby sweetsweet » Wed Jul 25, 2012 2:31 pm
Hello, here I have a big problem with Subsonic, my videos bug after 10 to 15 minutes of video playback, the video sacade and also the volume is really too small for videos.
Thank you for helping me, I'm French my English is not that good ;).
sweetsweet
Re: Big Problem
Postby sweetsweet » Wed Jul 25, 2012 10:03 pm
Nobody ? :'(
sweetsweet
Re: Big Problem
Postby BKKKPewsey » Thu Jul 26, 2012 2:44 pm
I would suggest using an online translator (or a better one :? )
and reposting as your original post doesn't make much sense.
Re: Big Problem
Postby sweetsweet » Thu Jul 26, 2012 5:20 pm
Bonsoir
Bon j'utilise actuellement Google traduction il semble ne pas bien fonctionner.
Alors voici le problème lorsque que je lance une vidéo avec Subsonic les images sont sacadées au bout de 10 20 minutes d'utilisation, ensuite 2nd problème, le volume de mes vidéos sont vraiment très faible que faire s'il vous plait ?.
Merci d'avance.
Cordialement.
sweetsweet
Re: Big Problem
Postby BKKKPewsey » Thu Jul 26, 2012 10:51 pm
Yep it would appear that Google translate is not doing a good job
good evening
Well I currently use Google translation seems not to work well.
So here's the problem when I launch a video with Subsonic images are sacadées after 10 20 minutes of use, then 2nd problem, the volume of my videos are really small as to please?.
Thank you in advance.
Cordially.
If any French speakers out there can do a better job please do so as apart from the low volume on videos
I have no idea on what is being said here. :?
Re: Big Problem
Postby sweetsweet » Mon Jul 30, 2012 2:12 pm
BKKKPewsey wrote:Yep it would appear that Google translate is not doing a good job
good evening
Cordially.
Lol ok thank you for responding, I try to express myself better.
1)The video player bug after 10 minutes of using the video freezes more or less.
2)The sound of the videos is very low, almost inaudible, how can I increase the sound to its maximum?.
Thank you for all.
sweetsweet
Re: Big Problem
Postby BKKKPewsey » Mon Jul 30, 2012 4:32 pm
With regard to the video freezing is there anything in the SS log to indicate a problem?
With the audio, have you turned up the volume in the video player window? and is the volume OK when using other video players?
Re: Big Problem
Postby sweetsweet » Tue Jul 31, 2012 5:41 pm
BKKKPewsey wrote:With regard to the video freezing is there anything in the SS log to indicate a problem?
Hello
Here is my SS LOG:
[2012-07-31 19:33:14,154] INFO DaoHelper - Checking database schema.
[2012-07-31 19:33:14,392] INFO DaoHelper - Done checking database schema.
[2012-07-31 19:33:14,572] INFO SearchService - Automatic index creation scheduled to run every 1 day(s), starting at Wed Aug 01 03:00:00 CEST 2012
[2012-07-31 19:33:14,606] INFO PodcastService - Automatic Podcast update scheduled to run every 24 hour(s), starting at Tue Jul 31 19:38:14 CEST 2012
[2012-07-31 19:33:20,606] WARN NetworkService - No UPnP router found.
[2012-07-31 19:33:33,857] INFO VersionService - Resolved local Subsonic version to: 4.6
[2012-07-31 19:33:34,044] INFO VersionService - Resolved latest Subsonic final version to: 4.6
[2012-07-31 19:33:34,044] INFO VersionService - Resolved latest Subsonic beta version to: 4.7.beta2
[2012-07-31 19:33:38,344] INFO PlaylistInputStream - admin listening to "downloads/Les Infideles.French.DVDRip.XviD-vh.avi"
[2012-07-31 19:33:38,347] DEBUG TranscodeInputStream - Starting transcoder: [/var/subsonic/transcode/ffmpeg] [-ss] [0] [-i] [/home/juju/downloads/Les Infideles.French.DVDRip.XviD-vh.avi] [-async] [1] [-b] [1000k] [-s] [608x256] [-ar] [44100] [-ac] [2] [-v] [0] [-f] [flv] [-vcodec] [libx264] [-preset] [superfast] [-threads] [0] [-]
[2012-07-31 19:33:38,354] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) ffmpeg version N-31780-gd5d74cf, Copyright (c) 2000-2011 the FFmpeg developers
[2012-07-31 19:33:38,354] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) built on Aug 9 2011 14:18:27 with gcc 4.5.2
[2012-07-31 19:33:38,354] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) configuration: --disable-ffplay --disable-ffprobe --disable-ffserver --enable-gpl --enable-nonfree --enable-postproc --enable-pthreads --enable-libfaac --enable-libmp3lame --enable-libvpx --enable-libtheora --enable-libvorbis --enable-libx264 --enable-libxvid --enable-zlib --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libvpx --enable-version3 --enable-bzlib --enable-static --disable-shared --extra-libs=-static --extra-cflags=--static
[2012-07-31 19:33:38,354] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavutil 51. 11. 1 / 51. 11. 1
[2012-07-31 19:33:38,354] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavcodec 53. 9. 1 / 53. 9. 1
[2012-07-31 19:33:38,355] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavformat 53. 6. 0 / 53. 6. 0
[2012-07-31 19:33:38,355] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavdevice 53. 2. 0 / 53. 2. 0
[2012-07-31 19:33:38,355] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libavfilter 2. 28. 1 / 2. 28. 1
[2012-07-31 19:33:38,355] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libswscale 2. 0. 0 / 2. 0. 0
[2012-07-31 19:33:38,355] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) libpostproc 51. 2. 0 / 51. 2. 0
[2012-07-31 19:33:38,378] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) [mpeg4 @ 0x9c819c0] Invalid and inefficient vfw-avi packed B frames detected
[2012-07-31 19:33:38,384] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Input #0, avi, from '/home/juju/downloads/Les Infideles.French.DVDRip.XviD-vh.avi':
[2012-07-31 19:33:38,384] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Metadata:
[2012-07-31 19:33:38,384] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) encoder : FairUse Wizard - http://fairusewizard.com
[2012-07-31 19:33:38,384] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Duration: 01:43:04.24, start: 0.000000, bitrate: 1894 kb/s
[2012-07-31 19:33:38,384] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Stream #0.0: Video: mpeg4 (Advanced Simple Profile), yuv420p, 608x256 [SAR 1:1 DAR 19:8], 25 tbr, 25 tbn, 25 tbc
[2012-07-31 19:33:38,384] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Stream #0.1: Audio: ac3, 48000 Hz, 5.1, s16, 448 kb/s
[2012-07-31 19:33:38,384] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) [buffer @ 0x9c83aa0] w:608 h:256 pixfmt:yuv420p tb:1/1000000 sar:1/1 sws_param:
[2012-07-31 19:33:38,384] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) [libx264 @ 0x9c82600] using SAR=1/1
[2012-07-31 19:33:38,384] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) [libx264 @ 0x9c82600] using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2 AVX
[2012-07-31 19:33:38,389] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) [libx264 @ 0x9c82600] profile High, level 2.1
[2012-07-31 19:33:38,389] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) [libx264 @ 0x9c82600] 264 - core 116 r2044 392e762 - H.264/MPEG-4 AVC codec - Copyleft 2003-2011 - http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x3:0x3 me=dia subme=1 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=16 chroma_me=1 trellis=0 8x8dct=1 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=6 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=250 keyint_min=25 scenecut=40 intra_refresh=0 rc=abr mbtree=0 bitrate=1000 ratetol=1.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 ip_ratio=1.40 pb_ratio=1.30 aq=1:1.00
[2012-07-31 19:33:38,392] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Output #0, flv, to 'pipe:':
[2012-07-31 19:33:38,392] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Metadata:
[2012-07-31 19:33:38,392] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) encoder : Lavf53.6.0
[2012-07-31 19:33:38,392] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Stream #0.0: Video: libx264, yuv420p, 608x256 [SAR 1:1 DAR 19:8], q=2-31, 1000 kb/s, 1k tbn, 25 tbc
[2012-07-31 19:33:38,393] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Stream #0.1: Audio: libmp3lame, 44100 Hz, 2 channels, s16, 64 kb/s
[2012-07-31 19:33:38,393] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Stream mapping:
[2012-07-31 19:33:38,393] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Stream #0.0 -> #0.0
[2012-07-31 19:33:38,393] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Stream #0.1 -> #0.1
[2012-07-31 19:33:38,393] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Press [q] to stop, [?] for help
[2012-07-31 19:33:38,393] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) Input stream #0.1 frame changed from rate:48000 fmt:s16 ch:6 to rate:48000 fmt:s16 ch:2
[2012-07-31 19:33:38,413] DEBUG InputStreamReaderThread - (/var/subsonic/transcode/ffmpeg) [mpeg4 @ 0x9c819c0] Invalid and inefficient vfw-avi packed B frames detected
To the sounds there are no problems with VLC but with subsonic sound is really low.
sweetsweet
Re: Big Problem
Postby BKKKPewsey » Tue Jul 31, 2012 7:10 pm
sweetsweet wrote:To the sounds there are no problems with VLC but with subsonic sound is really low.
BKKKPewsey wrote:With the audio, have you turned up the volume in the video player window?
Re: Big Problem
Postby sweetsweet » Tue Jul 31, 2012 7:12 pm
Yes.
sweetsweet
Re: Big Problem
Postby BKKKPewsey » Wed Aug 01, 2012 1:06 am
Can you test using a video with a normal stereo soundtrack as it may be the 6 ch encoding that is a problem.
I just used a test avi with a 5+1 soundtrack and that played back no problem in SS via browser :?
Re: Big Problem
Postby sweetsweet » Wed Aug 01, 2012 12:37 pm
BKKKPewsey wrote:Can you test using a video with a normal stereo soundtrack as it may be the 6 ch encoding that is a problem.
Hello ok but the problem occurs on all my videos, I just noticed that ffmpeg uses 130% of my cpu o_o.
The problem is over here.
sweetsweet
Re: Big Problem
Postby sweetsweet » Wed Aug 01, 2012 1:56 pm
I can give you access to my SubSonic if you want you'll see that the sound is very low and jwplayer freeze after 10 minutes.
sweetsweet
Re: Big Problem
Postby BKKKPewsey » Wed Aug 01, 2012 2:02 pm
Send me a link via a pm
Re: Big Problem
Postby sweetsweet » Wed Aug 01, 2012 2:10 pm
Done.
sweetsweet
Users browsing this forum: No registered users and 41 guests
