[SOLVED] Random Playlist does not work (4.6)
Postby NoZomIBK » Tue Jul 31, 2012 6:58 pm
i have just installed subsonic on my centos server, fine software.
but when i try to use the random playlist under the more menu, it just clears the current playlist and nothing more.
i have found no erroroutput in the log produced by the random playlist.
is it already known or is just something f***ed up at my installation?
all needed folders are writeable and everything.
greets
MOD: Please do not use swear words in the forum
NoZomIBK
Re: Random Playlist does not work (4.6)
Postby BKKKPewsey » Tue Jul 31, 2012 7:06 pm
It does work OK but sometimes you have to "prompt" the browser to display it.
Right click & reload frame in the playlist area usually makes it show up.
Postby NoZomIBK » Tue Jul 31, 2012 9:00 pm
Nope... Playlist is empty and listening player becomes quite
I am a programmer, so i have a little idea of what i am doing
any other ideas?
if you need further information, say what you need and i will try to provide it
thanks
NoZomIBK
Postby MadEvil » Tue Jul 31, 2012 9:11 pm
i found this problem also in the 4.7 beta
viewtopic.php?f=4&t=9411&p=41804#p41804
but this should fixed in the 4.7 beta2 release
best regards
Madsonic Developer
MadEvil
Postby NoZomIBK » Tue Jul 31, 2012 9:23 pm
Problem solved, 4.7.b2 works ;)
NoZomIBK
