Bug in adding/scaning Music (4.7.beta2)
Postby NoZomIBK » Wed Aug 01, 2012 10:01 am
I have two Musicfolder. One for all Music and one for the random playlist
my subsonic is playing a random playlist out of the playlist folder.
i tried to add a zip file to both folders. in music folder no problem, added and everything is fine. but in playlist folder nothing has changed.
files where on the server but not in library. i tried a manual folder scan, no effect.
i removed all files in playlist folder, rescan, no change...
after i stoped and cleared the playlist, a rescan shows effects.
no error messages in logfile
feel free to ask if you need further informations
PS: do you have a bug-reporting system, where i can report bugs in the future?
NoZomIBK
Re: Bug in adding/scaning Music (4.7.beta2)
Postby BKKKPewsey » Wed Aug 01, 2012 1:47 pm
NoZomIBK wrote:PS: do you have a bug-reporting system, where i can report bugs in the future?
You have just used it :)
There is a known problem with the current beta release with regard to folder scanning.
It will be fixed (hopefully :roll: ) on the next release.
