SharedPreferences prefs = this.getSharedPreferences(Constants.PREFERENCES_FILE_NAME, 0);
String value = this.getResources().getString(R.string.download_location_name);
String rootPath = prefs.getString(value ,"");
FileUtilDynamic utilDyn = new FileUtilDynamic();
if(rootPath != null && !rootPath.equals("")){
utilDyn.setRootMusicFolder(FileUtilDynamic.createDirectory(rootPath));
DownloadServiceImpl test = (DownloadServiceImpl) DownloadServiceImpl.getInstance(utilDyn);
return DownloadServiceImpl.getInstance(utilDyn);u-foka wrote:Subsonic does have this feature!
You should look at settings/general/Articles to ignore on your pc... or maybe update your subsonic server to a more recent version (it's there since I use subsonic so I don't know when it's implemented). But the default setting have 'The' to be ignored.
adolgov wrote:sindre_mehus wrote:happy_red wrote:I've just upgraded from a G1 to a Galaxy S and Subsonic can't find my music on my sd card. This is because the Galaxy S has 8GB of built in storage and adds the sd card as a 'sd' folder in the file system of its storage.
Could you add a new feature to configure the root folder for Subsonic so I can point it at the new sd card location? I don't want to us the built in memory as it is smaller than my sd card.
If you need any info on file structures or someone to debug for you, give me a shout.
Thanks.
I don't fully understand this. Subsonic should save music on the SD card, no matter if it's mounted as "/sd", "/sdcard" or anything else.
In which directory is Subsonic saving files on your Galaxy?
Sindre,
I also recently got a Galaxy S. The way that they do it is that it has a few gigs of app storage in flash, but the 8 or 16GB of device storage is an internal SD card (which is mounted on /sdcard). You can add your own, second SD card (accessible externally) to increase the storage capacity, and this is mounted on /sdcard/sd. I think that the request is asking for user-configurable storage location to be able to choose the user-added SD card rather than the internal SD card storage (which is the default Android SD card storage on the Galaxy S).
Andrey
