<script type="text/javascript" src="<c:url value="/script/jwplayer.js"/>"></script>function createPlayer() {
var flashvars = {
backcolor:"<spring:theme code="backgroundColor"/>",
frontcolor:"<spring:theme code="textColor"/>",
var params = {
allowfullscreen:"true",
allowscriptaccess:"always"
var attributes = {
swfobject.embedSWF("<c:url value="/flash/jw-player-5.6.swf"/>", "placeholder", "340", "24", "9.0.0", false, flashvars, params, attributes);
}function createPlayer() {
jwplayer("placeholder").setup({
flashplayer:"<c:url value="/flash/jw-player-5.8.swf"/>",
controlbar:"bottom",
width:"340",
height:"24",
modes: [
{type: "html5"},
{type: "flash", src:"<c:url value="/flash/jw-player-5.8.swf"/>"},
{type: "download"}
}tyleulen007 wrote:Citlali, did you also change the videoPlayer.jsp file? My understanding is that the playlist.jsp file only affects the music player, not video.
function init() {
skin:"<c:url value="/flash/whotube.zip"/>",
// plugins:"metaviewer-1",
screencolor:"000000",
controlbar:"over",
autostart:"false",
bufferlength:3,
provider:"video"
width: "${model.popout ? "100%" : "600"}",
height: "${model.popout ? "85%" : "360"}",
modes: [
{type: "html5"},
{type: "download"}
}Citlali wrote:tyleulen007 wrote:Citlali, did you also change the videoPlayer.jsp file? My understanding is that the playlist.jsp file only affects the music player, not video
Yes I did. However, I don't have any video files in my setup so I never tested it. Here is the code I put in there.
swfobject.embedSWF("<c:url value="/flash/jw-player-5.9.swf"/>", "placeholder1", width, height, "9.0.0", false, flashvars, params, attributes);
Richard Fearnhead wrote:
How does that tie in with the code below it in the original file?
- Code: Select all
seems to be the method the videoPlayer.jsp uses to embed the flash object on the page, and I think for html 5 we need to use jwplayer.js to initiate the player. Where I'm confused is are these two methods compatible with each other for example does jwplayer.js know what to do with 'flashvars'?
I guess my question is how is the embedding done in your modified code so that the web page doesn't inject the "Get flash player" link and instead attempts to present a html 5 player with the correct parameters (as set in flashvars, params and attributes) to that player?
A before and after of your videoPlayer.jsp file would be great as I'm not particularly sure what code to change/delete/keep/insert from the snippet you provided.
Please forgive me if I'm missing something I'm new to coding jsp, but I get the feeling you are really close and I'm just itching to get video working on my Android, which doesn't support flash.
<%@ page language="java" contentType="text/html; charset=utf-8" pageEncoding="iso-8859-1" %>
<html>
<head>
<%@ include file="head.jsp" %>
<sub:url value="videoPlayer.view" var="baseUrl"><sub:param name="path" value="${model.video.path}"/></sub:url>
<sub:url value="main.view" var="backUrl"><sub:param name="path" value="${model.video.parent.path}"/></sub:url>
<sub:url value="/stream" var="streamUrl">
</sub:url>
<script type="text/javascript" src="<c:url value="/script/swfobject.js"/>"></script>
<script type="text/javascript" src="<c:url value="/script/prototype.js"/>"></script>
<script type="text/javascript" src="<c:url value="/script/scripts.js"/>"></script>
<script type="text/javascript" language="javascript">
var player;
var position;
var maxBitRate = ${model.maxBitRate};
var timeOffset = ${model.timeOffset};
function init() {
var flashvars = {
controlbar:"over",
autostart:"false",
bufferlength:3,
provider:"video"
var params = {
var attributes = {
var width = "${model.popout ? '100%' : '600'}";
var height = "${model.popout ? '85%' : '360'}";
swfobject.embedSWF("<c:url value="/flash/jw-player-5.6.swf"/>", "placeholder1", width, height, "9.0.0", false, flashvars, params, attributes);
function playerReady(thePlayer) {
player = $("player1");
player.addModelListener("TIME", "timeListener");
<c:if test="${not (model.trial and model.trialExpired)}">
play();
</c:if>
function play() {
var list = new Array();
list[0] = {
file:"${streamUrl}&maxBitRate=" + maxBitRate + "&timeOffset=" + timeOffset + "&player=${model.player}",
duration:${model.duration} - timeOffset,
provider:"video"
player.sendEvent("LOAD", list);
player.sendEvent("PLAY");
function timeListener(obj) {
var newPosition = Math.round(obj.position);
if (newPosition != position) {
position = newPosition;
updatePosition();
function updatePosition() {
var pos = getPosition();
var minutes = Math.round(pos / 60);
var seconds = pos % 60;
var result = minutes + ":";
if (seconds < 10) {
result += "0";
result += seconds;
$("position").innerHTML = result;
function changeTimeOffset() {
timeOffset = $("timeOffset").getValue();
play();
function changeBitRate() {
maxBitRate = $("maxBitRate").getValue();
timeOffset = getPosition();
play();
function popout() {
var url = "${baseUrl}&maxBitRate=" + maxBitRate + "&timeOffset=" + getPosition() + "&popout=true";
popupSize(url, "video", 600, 400);
window.location.href = "${backUrl}";
function popin() {
window.opener.location.href = "${baseUrl}&maxBitRate=" + maxBitRate + "&timeOffset=" + getPosition();
window.close();
function getPosition() {
return parseInt(timeOffset) + parseInt(position);
</script>
</head>
<body class="mainframe bgcolor1" style="padding-bottom:0.5em" onload="init();">
<c:if test="${not model.popout}">
<h1>${model.video.title}</h1>
</c:if>
<c:if test="${model.trial}">
<fmt:formatDate value="${model.trialExpires}" dateStyle="long" var="expiryDate"/>
<p class="warning" style="padding-top:1em">
<c:choose>
<c:when test="${model.trialExpired}">
<fmt:message key="networksettings.trialexpired"><fmt:param>${expiryDate}</fmt:param></fmt:message>
</c:when>
<c:otherwise>
<fmt:message
key="networksettings.trialnotexpired"><fmt:param>${expiryDate}</fmt:param></fmt:message>
</c:otherwise>
</c:choose>
</p>
</c:if>
<div id="wrapper" style="padding-top:1em">
<div id="placeholder1"><a href="http://www.adobe.com/go/getflashplayer" target="_blank"><fmt:message key="playlist.getflash"/></a></div>
</div>
<div style="padding-top:0.7em;padding-bottom:0.7em">
<span id="position" style="padding-right:0.5em">0:00</span>
<select id="timeOffset" onchange="changeTimeOffset();" style="padding-left:0.25em;padding-right:0.25em;margin-right:0.5em">
<c:forEach items="${model.skipOffsets}" var="skipOffset">
<c:choose>
<c:when test="${skipOffset.value - skipOffset.value mod 60 eq model.timeOffset - model.timeOffset mod 60}">
<option selected="selected" value="${skipOffset.value}">${skipOffset.key}</option>
</c:when>
<c:otherwise>
<option value="${skipOffset.value}">${skipOffset.key}</option>
</c:otherwise>
</c:choose>
</c:forEach>
</select>
<select id="maxBitRate" onchange="changeBitRate();" style="padding-left:0.25em;padding-right:0.25em;margin-right:0.5em">
<c:forEach items="${model.bitRates}" var="bitRate">
<c:choose>
<c:when test="${bitRate eq model.maxBitRate}">
<option selected="selected" value="${bitRate}">${bitRate} Kbps</option>
</c:when>
<c:otherwise>
<option value="${bitRate}">${bitRate} Kbps</option>
</c:otherwise>
</c:choose>
</c:forEach>
</select>
</div>
<c:choose>
<c:when test="${model.popout}">
<div class="back"><a href="javascript:popin();"><fmt:message key="common.back"/></a></div>
</c:when>
<c:otherwise>
<div class="back" style="float:left;padding-right:2em"><a href="${backUrl}"><fmt:message key="common.back"/></a></div>
<div class="forward" style="float:left;"><a href="javascript:popout();"><fmt:message key="videoPlayer.popout"/></a></div>
</c:otherwise>
</c:choose>
</body>
</html>
<html>
<head>
</sub:url>
var player;
var position;
function init() {
controlbar:"over",
autostart:"false",
bufferlength:3,
provider:"video"
modes: [
{type: "html5"},
{type: "download"}
play();
</c:if>
function play() {
list[0] = {
provider:"video"
updatePosition();
if (seconds < 10) {
result += "0";
result += seconds;
play();
play();
function popout() {
function popin() {
window.close();
</script>
</head>
</c:if>
<c:choose>
</c:when>
<c:otherwise>
<fmt:message
</c:otherwise>
</c:choose>
</p>
</c:if>
</div>
<c:choose>
</c:when>
<c:otherwise>
</c:otherwise>
</c:choose>
</c:forEach>
</select>
<c:choose>
</c:when>
<c:otherwise>
</c:otherwise>
</c:choose>
</c:forEach>
</select>
</div>
<c:choose>
</c:when>
<c:otherwise>
</c:otherwise>
</c:choose>
</body>
</html>
