Volume Normalization
Re: Volume Normalization
Postby grant420 » Sat Aug 09, 2014 4:39 am
Fred,
Your solution for using Winamp calculated replay gain via Subsonic is great, however my mp3 files that at various bitrates from 160kbps-320kbps are all being re-encoded at 128kbps. I was able to change the ffmpeg command to force them to stream at 320, which is OK. Ideally, I would configure it to honor the original file bitrate like Subsonic normally does w/o your replay gain method in place. Can you assist?
grant420
Postby FredWallace18 » Tue Aug 26, 2014 4:39 pm
grant420 wrote:Fred,
Hmm, that's what the -ab %2 was supposed to do. Maybe -b:a %2k instead? I don't think I've had that trouble.
FredWallace18
Postby FredWallace18 » Mon Dec 01, 2014 10:07 pm
DSub for Android now supports the replaygain tag natively. I for one am disabling transcoding altogether at applying the gain at time of playing as it's meant to be (at least for my phone, which is half my listening).
FredWallace18
Previous
