Android app feature requests
Postby flyerwire » Mon May 10, 2010 2:41 pm
basically the only time i use stored MP3's is when i am not in a 3g area. AT&T probably hates me and this app as it has easily increased the amount of data i use in a month 10-20x I love it
flyerwire
Postby dave w » Tue May 11, 2010 9:02 pm
Just wanted to add another vote for an exit/stop download type feature. As of now, if I stop streaming through subsonic and forget to separately shut down the app, downloading the playlist is really a battery drain, as well as an unnecessary use of bandwidth.
Overall, great app! Thanks.
dave w
Postby dave w » Wed May 12, 2010 5:15 pm
Another great addition would be a widget for the phone homescreen. Even a simple one to merely pause/play.
dave w
Postby rwagter » Wed May 12, 2010 8:15 pm
the ability to control a predefined jukeboxplayer (so I can use my androidphone as a remote just like squeezecommander).
rwagter
Postby linuxman » Wed May 12, 2010 8:52 pm
Please add a feature so that you can change what music folder you access. I have 1637 artists now and it's tedious to pick something to play on my phone.
linuxman
Postby hollen » Thu May 13, 2010 7:21 am
Firstly Great App!! Bought my andriod phone because of it!
Requests:
+1 remote jukebox
+1 exit button
+1 que button ( maybe you can squeese it in between "play" and "more" or maybe have it show up in landscape view)
+1 for widget
+1 automatic cash management (Perhaps an adjusteble upper limit)
Last my own (as far as i remember)
Refresh: Refresh my music. I have an isue if musik is added, when i have the app running. it doesn't show up on the list.
Thanks for this great app.
hollen
Postby dcastellani » Tue May 18, 2010 2:36 pm
Whats the latest on the Android app? I use subsonic+android app+subair on a daily basis so I am curious about any potential improvements.
dcastellani
Postby munkiepus » Wed May 19, 2010 12:04 am
Not sure if this has been mentioned before. But i'd like to see the now playing tune on the android app turn up in the now playing section of the subsonic web interface. At the moment this only happens for un-cached music. This would allow last.fm scrobbling and better overall statistics for the most frequent/recent tunes in the subsonic app.
I realise that the cached music is to allow offline playing in the android app, but when there is a data connection, it would be nice to show what is currently being played from android. It can be achieved by deleting the cache but that seems a bit bandwidth intensive just to get usage stats.
Anyway, Killer App, Sindre you're a legend ;)
munkiepus
Postby munkiepus » Wed May 19, 2010 12:06 am
I should probably put a +1 for cache limit management and a +1 for jukebox remote control too. (although stats from the android app 1st)
munkiepus
Postby Hobbit13 » Wed May 19, 2010 9:30 am
Perhaps it's just me, but I want to request a version that doesn't freezes all the time.... I tried the app on a HTC Magic. And with a lot of waiting (minutes) I got it playing a folder that was close to the root folder. It always times out on deeper folders, and search doesn't work at all (the app crashes after 2 minutes of waiting).
I ran subsonic 3.9, and the android app from that time. The subsonic database is rather large (+100K). But searching etc in the Webapp goes perfect.
Is the current version better?
(P.S. The Adobe Air app has comparable problems)
Hobbit13
Postby amiantos » Fri May 21, 2010 5:06 pm
I think it would be beneficial if two things happened regarding problems with rapid-scrobbling when using the app...
1.) Disable Subsonic's scrobbling when using the Android app.
2.) Make the Subsonic Android app compatible with Last.FM/other scrobbling functions.
This way songs will only scrobble when they are actually played, and it'll show that you're listening from Android in your last.FM profile, as if that is important.
http://staires.org
amiantos
Postby dcastellani » Sat May 22, 2010 5:20 am
Maybe an exit button isnt really a good idea. I think it might go against how android is designed to operate and maybe a function to simply stop playlist/queue downloads would be better.
Have a read and tell me what you think.
http://android-developers.blogspot.com/ ... d-way.html
dcastellani
Postby the_slain_man » Sun May 23, 2010 8:30 pm
1. Support for buttons on my bluetooth headset ( Sony MW600 ) it only works when screen is on and when you are inside subsonic app right now.
2. Long press album should show que album aswell as play
3. Cache management, my sdcard does fill upp some times
4. Long press on artist should list play artist
the_slain_man
Postby Poffa » Sun May 23, 2010 9:17 pm
the_slain_man wrote:3. Cache management, my sdcard does fill upp some times
+1
I'd also like a feature to allow users to set their own bitrate, but only lower or equal to what the admin has set. Now I have users using two account depending on if they're using a phone app or the web interface/subAir.
Poffa
Postby sindre_mehus » Tue May 25, 2010 1:54 pm
dcastellani wrote:Whats the latest on the Android app? I use subsonic+android app+subair on a daily basis so I am curious about any potential improvements.
Having released Subsonic 4 a couple of weeks ago, I'm just about to start working on an update of the Android app.
I haven't yet decided exactly what to put into it, but I will prioritize usability improvements and bug fixes over new features (although I do intend to add shuffle play).
Thanks for all your feedback and requests - they are most valuable when planning future releases!
