1+ for bluetooth remote controlwiltshi wrote:Sindre,
I am having issues with the media control keys, as described here. It looks like it can be fixed by using the audio focus API in android 2.2.
Do you have plans to add support for the audio focus api in the near future? If you don't have time, I am willing to take a look and submit a patch to at least make the remote buttons work correctly, and perhaps fully support audio focus.
happy_red wrote:I've just upgraded from a G1 to a Galaxy S and Subsonic can't find my music on my sd card. This is because the Galaxy S has 8GB of built in storage and adds the sd card as a 'sd' folder in the file system of its storage.
Could you add a new feature to configure the root folder for Subsonic so I can point it at the new sd card location? I don't want to us the built in memory as it is smaller than my sd card.
If you need any info on file structures or someone to debug for you, give me a shout.
Thanks.
sindre_mehus wrote:happy_red wrote:I've just upgraded from a G1 to a Galaxy S and Subsonic can't find my music on my sd card. This is because the Galaxy S has 8GB of built in storage and adds the sd card as a 'sd' folder in the file system of its storage.
Thanks.
I don't fully understand this. Subsonic should save music on the SD card, no matter if it's mounted as "/sd", "/sdcard" or anything else.
In which directory is Subsonic saving files on your Galaxy?
