Please fix caching issues
Postby toniflueckiger » Thu Sep 06, 2012 11:13 am
Please fix the caching issues at the android app.
I have 1 Subsonic server. This subsonic server is reachable by 2 domain names (dyndns and no-ip). If i open it via dyndns, then i see an old list. If i open it with no-ip, then all is ok and the list is actual.
In cause of that, im sure that the subsonic app is caching the list. The app is not reading it out each time as is should do.
Please deactivate that list-caching at the subsonic app, or add a button at the settings to clean up the cache. At the moment the only possibility to fix that is to deinstall/reinstall the subsonic app.
With a browser, i have the same results on both domains. Im really sure that the android app is the problem.
(Fast access mode is disabled)
Thanks and best regards,
Toni
toniflueckiger
Re: Please fix caching issues
Postby bushman4 » Thu Sep 06, 2012 11:20 am
Just hit the refresh button at the top of the media library list... it looks like two arrows pointing into each other.
That's what that button is for...
Glenn
Glenn Sullivan
90 regular Subsonic Users
Library as of 2024-10-28:
4,527 artists
19,996 albums
282,151 songs
10201.40 GB
41,583 hours
Postby toniflueckiger » Thu Sep 06, 2012 11:34 am
That i have already tryed.
I've tryed it with "Clean up database" , "Refresh" , "Scan media folders now" and the Refresh Button at the subsonic app. Nothing helped.
I've tryed too to rename the connection at the subsonic app. Helped not.
It seems that the subsonic app is caching that. The caching is not linked with the name of the configuration, its linked with the position under Settings --> Servers.
toniflueckiger
Postby toniflueckiger » Thu Sep 06, 2012 11:38 am
I've found the solution to fix that manually:
Android system settings --> App manager --> Subsonic --> Delete Cache .
So 100% the caching of the subsonic app is the problem, not the subsonic server or something other.
Please fix that issue at the android app.
Toni
toniflueckiger
