Mapped Drive
Mapped Drive
Postby koalangebut » Thu Jan 17, 2008 8:01 am
I have installed subsonic and it's running without any trouble but why i can't see any multimedia files in the list if the music folder is located on a mapped drive?
Is there any workaround for this problem? Because my drive is running out of space and i intending to move all the multimedia files to my mapped drive.
koalangebut
Postby mistaox » Fri Jan 18, 2008 7:49 pm
Are u using Windows?
use a UNC path like this:
\\NAMEOFPC\NAMEOFSHARE
I have a pc called "DATA01" with a Share called "Movies". so my entires look like this:
\\DATA01\Movies
mistaox
Postby FreeMan » Thu Feb 21, 2008 2:20 pm
I'm in the process of migrating libraries to another machine with more drive space, and I've run into the same issue.
It doesn't matter whether I use drive letters or UNC, I don't seem to be able to access the files on the other machine. I know that the machine running Subsonic can see the share point on the machine with the drive space (just moved the files last night), but Subsonic doesn't seem to be able to see them when I update the search index.
Any tips?
Both boxes are WinXPProSP2, fully patched this week.
FreeMan
Postby kdid » Tue Feb 26, 2008 1:48 pm
You find some info about what the problem could be here:
http://forum.subsonic.org/forum/viewtopic.php?t=1082
-- kdid
kdid
