[SMALL BUG] Duplicate songs in playlist
Postby pslavickas » Tue Oct 23, 2012 3:27 pm
There is a bug (easily reproducible) when you add more than one instance of the same song to your current playlist: When a song with 2 entries in the current playlist is being played, then both songs are signaled to be 'playing' regardless of which song you had selected to be played. Not a big deal, but I think it's worth mentioning.
Thanks again for your great software!!
pslavickas
Re: [SMALL BUG] Duplicate songs in playlist
Postby gurutech » Sun Oct 28, 2012 9:16 pm
I'm having the same issue, but it happens when I select several songs through the "random playlist" option. I find that I have multiple instances of the same song (not just different versions, I mean the SAME song!)
I can manually remove the duplicates, which is what I do before saving the playlist. Once the playlist is saved, it's OK.
gurutech
Postby GJ51 » Mon Oct 29, 2012 2:01 am
Known bug. Been on the board for a long time.
