Alphabetically sort media folders
Postby ajkessel » Sun Nov 11, 2012 5:02 pm
I use media folders as a proxy for genres and have about 20. The Subsonic web interface just shows the media folders in the order they are entered in the settings dialog. There does not appear to be any way to sort them alphabetically. Moreover, if you wanted to change the media folder list to be alphabetical through the settings interface, you would have to go and manually delete all the folders and re-add them. Is there any better solution for getting alphabetized media folders, or could a sort option be added?
ajkessel
Re: Alphabetically sort media folders
Postby Subsinus » Wed Nov 28, 2012 8:11 am
Same problem here...
I cannot find the Albums, because they are not sorted by alphabet, there are too many of them.
This is a big gap at Subsonic.
Subsinus
Postby metaflux » Thu Mar 28, 2013 8:02 am
Is there a solution for that? i want to have my music sorted by the folder name NOT by any ID3 tag!!!
metaflux
