Read art from parent folders of multidisc albums
Postby tnt533 » Thu Dec 13, 2012 6:53 pm
I organize double disc releases in their own folder under a parent folder for the entire release. It's cleaner when dealing with the files outside of the player and allows for a more standardized formatting of tags (track numbers) and file names. What I would love to see is album art being read from the parent folder as well and then displayed on the artist level with the other non-multidisc releases. The only way to make that happen as of now is to actually put a track in the parent folder with the art file and then Subsonic will read and display it but it's a messy solution. I won't do that. All my multidisc releases are sorted to the top and the art isn't displayed with the rest of the singledisc albums. =( I can't bring myself to just dump all tracks from all discs into a single folder either. I have some box sets that comprise 80 to 100+ tracks and several box sets have different art for each disc and I don't embed art into the files, instead choosing to do a single folder.jpg in the album folder. It's more manageable that way. If you need to change art you just change that one file and it's the most cross platform solution outside of embedded art, which I greatly dislike.
Sindre, please make Subsonic read the art file out of folders without tracks in them. Make it an optional thing if need be. I understand it could be messy for those who don't put in the time to keep an organized collection but I'm guessing most of those individuals don't care about this subject any way. For those that keep entire scan sets of covers, back and insert then make a standard for naming the art that one wants displayed. I use folder.jpg because that's also used by many other applications for cross platform support. WMP12 for instance uses the folder.jpg convention as well.
tnt533
AW: Read art from parent folders of multidisc albums
Postby MadEvil » Fri Dec 14, 2012 1:23 am
Hi, i know the problem with multidisc albums in default subsonic 4.7,
so i decide to change this in my Madsonic Mod. Give it a try, if it
doesn't work give me a little feedback.
viewtopic.php?f=15&t=10445
Best regards
Madsonic Developer
MadEvil
Re: Read art from parent folders of multidisc albums
Postby tnt533 » Fri Dec 21, 2012 8:01 am
I appreciate your suggestion and your project looks interesting but I am not prepared to replace vanilla. It's working with 100% up-time at this point. *Knock on wood*
tnt533
Postby agersant » Mon Feb 18, 2013 8:58 pm
I am in the very similar situation: I have a very well sorted collection and I split multidisc releases into subfolders. As a result album art doesn't work for multidisc releases. Here is an example setup where Okami Original Soundtrack doesn't display its cover art.
My local media player (foobar) copes with this by letting me use "../Folder.jpg" as a source for cover art but this doesn't seem to work in subsonic.
EDIT: I've just noticed Subsonic also considers that the individual discs are albums named Disc 1, Disc 2, etc. =(
agersant
Postby amer » Mon Nov 04, 2013 9:02 am
My vote +1 on this feature request.
I have the same problem.
amer
Postby lolomm » Tue Dec 03, 2013 2:34 pm
+1
lolomm
