Go to album/folder after finding a song with a search ?
Postby webvan » Fri Jan 25, 2013 9:00 pm
I might be missing something but I can't seem to find a way to "back out" to the album and/or folder containing a song I've found during a search. That would be great as it's not always possible to identify the album containing that song, thanks!
webvan
Re: Go to album/folder after finding a song with a search ?
Postby GJ51 » Fri Jan 25, 2013 9:47 pm
I don't remember the defaults as I've changed my settings a long time ago, but if you go to Settings/Personal and check the box for Album to display in the playlist that will give you a link back to the album the track is playing from.
I also have mine checked for albums to display in the upper browse window which should work also.
Postby webvan » Fri Jan 25, 2013 9:54 pm
Thanks, I should probably have clarified that my main Subsonic player is iSub on my iPhone so that's probably were I should make my request...I took a look at the settings and there's no option for the album there it seems :-(
webvan
Postby daneren2005 » Fri Jan 25, 2013 10:22 pm
Yah I don't think the iSub dev even looks here.
Postby GJ51 » Fri Jan 25, 2013 10:54 pm
Sad to say, but it's begining to look like the application dev doen't either.
4.8 beta should be coming out within a month or so.
