IP block or ban Function
Postby agegold » Thu Mar 07, 2013 2:59 pm
I'm a SubSonic user who donated before.
Since few days ago, looks like someone tries to login to my SubSonic server so many times, with wrong password.
So I'd like to kindly request you to make a function which can block specific IP for about 4~5 hours when some user failed to login more than five times.
agegold
Re: IP block or ban Function
Postby gurutech » Thu Mar 07, 2013 9:45 pm
Block the IP address on your firewall/router.
gurutech
Postby agegold » Fri Mar 08, 2013 5:13 am
I use firewall but ip always change
agegold
Postby jol » Fri Mar 08, 2013 10:36 pm
agegold wrote: Since few days ago, looks like someone tries to login to my SubSonic server so many times, with wrong password.
I don´t see the benefit to ban the IP address if the user cannot authenticate successfully anway. Or does it lock out a legitimate user (not sure whether subsonic does that, there are pros and cons) because you shared credentials back some time?
Best regards, jol
Subsonic 4.7 running on Acer H340 with LDAP authentication / Windows Home Server 2011 - Android client (3.5)
jol
Postby daneren2005 » Fri Mar 08, 2013 11:19 pm
Ip banning is to prevent brute forcing. Right you you could pretty easily write a script which could try the most common 2-3 million passwords in less then a day, giving you access to 99% of the accounts on a standard server.
