Running off of the router
Postby hemlockII » Tue Jul 23, 2013 12:35 am
Hello, I very much like the idea of subsonic. However I was wondering, since I do not have a 24/7 always-on pc (even if not for electricity costs, for that awful fan noise) whereas this is exactly the case for the router (like most home users I'd guess) can I not just attach an external HDD to my router and run subsonic thru there? Not sure if this would be possible, but since there are open-source firmwares(like dd-wrt) for routers these days, maybe adding subsonic support would be trivial?
Scouring the faq & forums I didn't come across something like this, so would anyone think this is a feasible idea?
hemlockII
Re: Running off of the router
Postby daneren2005 » Tue Jul 23, 2013 2:46 am
If the router supports java it might be possible for you to add it yourself. If it doesn't support java it will never happen since it would require a complete re-write just for a small edge case.
