subsonic registration page :D and plugins
Postby 2jmans » Sat Oct 05, 2013 6:57 pm
I would like to see a reregistration page for subsonic. Instead of a admin making an account.. :) It should at least be an option for the subsonic user. I think it would be cool. Also they could make it so a person that registers needs admin approval before they can see your library of media.. Just a thought.. Also maybe have a plugin support too :) So an user can customize subsonic and such :)
2jmans
Re: subsonic registration page :D and plugins
Postby gurutech » Sun Oct 06, 2013 12:06 am
http://forum.madsonic.org/viewtopic.php ... 35e4b97bf9
This should work with Subsonic also.
gurutech
Postby 2jmans » Sun Oct 06, 2013 2:13 am
I would like to thanks for replying to my post. I tried your method but to no avail.. I get this =(
Parse error: syntax error, unexpected ':' in E:\xampp\htdocs\subsonic\include\fg_membersite.php on line 61
ps Im very new to the world of sql servers and apache and php ect. But I learn pretty fast =)
also what you made is pretty impressive, did you write the scripts yourself?
2jmans
Postby gurutech » Sun Oct 06, 2013 2:34 am
Can you post that file here? You could check that file in Notepad, and check line 61 (you have to count down 61 lines though). You may see what's wrong with it right away.
gurutech
Postby 2jmans » Sun Oct 06, 2013 2:52 am
this is line 61
function SetWebsiteName($sitename)
$this->sitename = localhost:9657
it's just a test for now until I get my dynamic domain name service up Im curious to see this work so for now I'm using localhost to connect :P
I have the entire file
<?PHP
Registration/Login script from HTML Form Guide
V1.0
This program is free software published under the
terms of the GNU Lesser General Public License.
http://www.gnu.org/copyleft/lesser.html
This program is distributed in the hope that it will
be useful - WITHOUT ANY WARRANTY; without even the
implied warranty of MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
For updates, please visit:
http://www.html-form-guide.com/php-form ... -form.html
require_once("class.phpmailer.php");
require_once("formvalidator.php");
class FGMembersite
var $admin_email;
var $from_address;
var $username;
var $pwd;
var $database;
var $tablename;
var $connection;
var $rand_key;
var $error_message;
//-----Initialization -------
function FGMembersite()
$this->sitename = 'localhost:9657';
$this->rand_key = '0iQx5oBk66oVZep';
function InitDB($host,$uname,$pwd,$database,$tablename)
$this->db_host = $host;
$this->username = $uname;
$this->pwd = $pwd;
$this->database = $database;
$this->tablename = $tablename;
function SetAdminEmail($email)
$this->admin_email = $email;
$this->sitename = localhost:9657/subsonic
function SetRandomKey($key)
$this->rand_key = $key;
//-------Main Operations ----------------------
function RegisterUser()
if(!isset($_POST['submitted']))
return false;
$formvars = array();
if(!$this->ValidateRegistrationSubmission())
return false;
$this->CollectRegistrationSubmission($formvars);
if(!$this->SaveToDatabase($formvars))
return false;
if(!$this->SendUserConfirmationEmail($formvars))
return false;
$this->SendAdminIntimationEmail($formvars);
return true;
function ConfirmUser()
if(empty($_GET['code'])||strlen($_GET['code'])<=10)
$this->HandleError("Please provide the confirm code");
return false;
$user_rec = array();
if(!$this->UpdateDBRecForConfirmation($user_rec))
return false;
$this->SendUserWelcomeEmail($user_rec);
$this->SendAdminIntimationOnRegComplete($user_rec);
return true;
function Login()
if(empty($_POST['username']))
$this->HandleError("UserName is empty!");
return false;
if(empty($_POST['password']))
$this->HandleError("Password is empty!");
return false;
$username = trim($_POST['username']);
$password = trim($_POST['password']);
if(!isset($_SESSION)){ session_start(); }
if(!$this->CheckLoginInDB($username,$password))
return false;
$_SESSION[$this->GetLoginSessionVar()] = $username;
return true;
function CheckLogin()
$sessionvar = $this->GetLoginSessionVar();
if(empty($_SESSION[$sessionvar]))
return false;
return true;
function UserFullName()
return isset($_SESSION['name_of_user'])?$_SESSION['name_of_user']:'';
function UserEmail()
return isset($_SESSION['email_of_user'])?$_SESSION['email_of_user']:'';
function LogOut()
session_start();
$_SESSION[$sessionvar]=NULL;
unset($_SESSION[$sessionvar]);
function EmailResetPasswordLink()
if(empty($_POST['email']))
$this->HandleError("Email is empty!");
return false;
if(false === $this->GetUserFromEmail($_POST['email'], $user_rec))
return false;
if(false === $this->SendResetPasswordLink($user_rec))
return false;
return true;
function ResetPassword()
if(empty($_GET['email']))
return false;
if(empty($_GET['code']))
$this->HandleError("reset code is empty!");
return false;
$email = trim($_GET['email']);
$code = trim($_GET['code']);
if($this->GetResetPasswordCode($email) != $code)
$this->HandleError("Bad reset code!");
return false;
if(!$this->GetUserFromEmail($email,$user_rec))
return false;
$new_password = $this->ResetUserPasswordInDB($user_rec);
if(false === $new_password || empty($new_password))
$this->HandleError("Error updating new password");
return false;
if(false == $this->SendNewPassword($user_rec,$new_password))
$this->HandleError("Error sending new password");
return false;
return true;
function ChangePassword()
if(!$this->CheckLogin())
$this->HandleError("Not logged in!");
return false;
if(empty($_POST['oldpwd']))
$this->HandleError("Old password is empty!");
return false;
if(empty($_POST['newpwd']))
$this->HandleError("New password is empty!");
return false;
if(!$this->GetUserFromEmail($this->UserEmail(),$user_rec))
return false;
$pwd = trim($_POST['oldpwd']);
if($user_rec['password'] != md5($pwd))
$this->HandleError("The old password does not match!");
return false;
$newpwd = trim($_POST['newpwd']);
if(!$this->ChangePasswordInDB($user_rec, $newpwd))
return false;
return true;
//-------Public Helper functions -------------
function GetSelfScript()
return htmlentities($_SERVER['PHP_SELF']);
function SafeDisplay($value_name)
if(empty($_POST[$value_name]))
return'';
return htmlentities($_POST[$value_name]);
function RedirectToURL($url)
header("Location: $url");
exit;
function GetSpamTrapInputName()
return 'sp'.md5('KHGdnbvsgst'.$this->rand_key);
function GetErrorMessage()
if(empty($this->error_message))
return '';
$errormsg = nl2br(htmlentities($this->error_message));
return $errormsg;
//-------Private Helper functions-----------
function HandleError($err)
$this->error_message .= $err."\r\n";
function HandleDBError($err)
$this->HandleError($err."\r\n mysqlerror:".mysql_error());
function GetFromAddress()
if(!empty($this->from_address))
return $this->from_address;
$host = $_SERVER['SERVER_NAME'];
$from ="nobody@$host";
return $from;
function GetLoginSessionVar()
$retvar = md5($this->rand_key);
$retvar = 'usr_'.substr($retvar,0,10);
return $retvar;
function CheckLoginInDB($username,$password)
if(!$this->DBLogin())
$this->HandleError("Database login failed!");
return false;
$username = $this->SanitizeForSQL($username);
$pwdmd5 = md5($password);
$qry = "Select name, email from $this->tablename where username='$username' and password='$pwdmd5' and confirmcode='y'";
$result = mysql_query($qry,$this->connection);
if(!$result || mysql_num_rows($result) <= 0)
$this->HandleError("Error logging in. The username or password does not match");
return false;
$row = mysql_fetch_assoc($result);
$_SESSION['name_of_user'] = $row['name'];
$_SESSION['email_of_user'] = $row['email'];
return true;
function UpdateDBRecForConfirmation(&$user_rec)
return false;
$confirmcode = $this->SanitizeForSQL($_GET['code']);
$result = mysql_query("Select name, email from $this->tablename where confirmcode='$confirmcode'",$this->connection);
$this->HandleError("Wrong confirm code.");
return false;
$user_rec['name'] = $row['name'];
$user_rec['email']= $row['email'];
$qry = "Update $this->tablename Set confirmcode='y' Where confirmcode='$confirmcode'";
if(!mysql_query( $qry ,$this->connection))
$this->HandleDBError("Error inserting data to the table\nquery:$qry");
return false;
return true;
function ResetUserPasswordInDB($user_rec)
$new_password = substr(md5(uniqid()),0,10);
if(false == $this->ChangePasswordInDB($user_rec,$new_password))
return false;
return $new_password;
function ChangePasswordInDB($user_rec, $newpwd)
$newpwd = $this->SanitizeForSQL($newpwd);
$qry = "Update $this->tablename Set password='".md5($newpwd)."' Where id_user=".$user_rec['id_user']."";
$this->HandleDBError("Error updating the password \nquery:$qry");
return false;
return true;
function GetUserFromEmail($email,&$user_rec)
return false;
$email = $this->SanitizeForSQL($email);
$result = mysql_query("Select * from $this->tablename where email='$email'",$this->connection);
$this->HandleError("There is no user with email: $email");
return false;
$user_rec = mysql_fetch_assoc($result);
return true;
function SendUserWelcomeEmail(&$user_rec)
$mailer = new PHPMailer();
$mailer->CharSet = 'utf-8';
$mailer->AddAddress($user_rec['email'],$user_rec['name']);
$mailer->Subject = "Welcome to ".$this->sitename;
$mailer->From = $this->GetFromAddress();
$mailer->Body ="Hello ".$user_rec['name']."\r\n\r\n".
"Welcome! Your registration with ".$this->sitename." is completed.\r\n".
"\r\n".
"Regards,\r\n".
"Webmaster\r\n".
$this->sitename;
if(!$mailer->Send())
$this->HandleError("Failed sending user welcome email.");
return false;
return true;
function SendAdminIntimationOnRegComplete(&$user_rec)
if(empty($this->admin_email))
return false;
$mailer->AddAddress($this->admin_email);
$mailer->Subject = "Registration Completed: ".$user_rec['name'];
$mailer->Body ="A new user registered at ".$this->sitename."\r\n".
"Name: ".$user_rec['name']."\r\n".
"Email address: ".$user_rec['email']."\r\n";
return false;
return true;
function GetResetPasswordCode($email)
return substr(md5($email.$this->sitename.$this->rand_key),0,10);
function SendResetPasswordLink($user_rec)
$email = $user_rec['email'];
$mailer->AddAddress($email,$user_rec['name']);
$mailer->Subject = "Your reset password request at ".$this->sitename;
$link = $this->GetAbsoluteURLFolder().
'/resetpwd.php?email='.
urlencode($email).'&code='.
urlencode($this->GetResetPasswordCode($email));
"There was a request to reset your password at ".$this->sitename."\r\n".
"Please click the link below to complete the request: \r\n".$link."\r\n".
"Regards,\r\n".
"Webmaster\r\n".
$this->sitename;
return false;
return true;
function SendNewPassword($user_rec, $new_password)
$mailer->Subject = "Your new password for ".$this->sitename;
"Your password is reset successfully. ".
"Here is your updated login:\r\n".
"username:".$user_rec['username']."\r\n".
"password:$new_password\r\n".
"\r\n".
"Login here: ".$this->GetAbsoluteURLFolder()."/login.php\r\n".
"\r\n".
"Regards,\r\n".
"Webmaster\r\n".
$this->sitename;
return false;
return true;
function ValidateRegistrationSubmission()
//This is a hidden input field. Humans won't fill this field.
if(!empty($_POST[$this->GetSpamTrapInputName()]) )
//The proper error is not given intentionally
$this->HandleError("Automated submission prevention: case 2 failed");
return false;
$validator = new FormValidator();
$validator->addValidation("name","req","Please fill in Name");
$validator->addValidation("email","email","The input for Email should be a valid email value");
$validator->addValidation("email","req","Please fill in Email");
$validator->addValidation("username","req","Please fill in UserName");
$validator->addValidation("password","req","Please fill in Password");
if(!$validator->ValidateForm())
$error='';
$error_hash = $validator->GetErrors();
foreach($error_hash as $inpname => $inp_err)
$error .= $inpname.':'.$inp_err."\n";
$this->HandleError($error);
return false;
return true;
function CollectRegistrationSubmission(&$formvars)
$formvars['name'] = $this->Sanitize($_POST['name']);
$formvars['email'] = $this->Sanitize($_POST['email']);
$formvars['username'] = $this->Sanitize($_POST['username']);
$formvars['password'] = $this->Sanitize($_POST['password']);
function SendUserConfirmationEmail(&$formvars)
$mailer->AddAddress($formvars['email'],$formvars['name']);
$mailer->Subject = "Your registration with ".$this->sitename;
$confirmcode = $formvars['confirmcode'];
$confirm_url = $this->GetAbsoluteURLFolder().'/confirmreg.php?code='.$confirmcode;
$mailer->Body ="Hello ".$formvars['name']."\r\n\r\n".
"Thanks for your registration with ".$this->sitename."\r\n".
"Please click the link below to confirm your registration.\r\n".
"$confirm_url\r\n".
"\r\n".
"Regards,\r\n".
"Webmaster\r\n".
$this->sitename;
$this->HandleError("Failed sending registration confirmation email.");
return false;
return true;
function GetAbsoluteURLFolder()
$scriptFolder = (isset($_SERVER['HTTPS']) && ($_SERVER['HTTPS'] == 'on')) ? 'https://' : 'http://';
$scriptFolder .= $_SERVER['HTTP_HOST'] . dirname($_SERVER['REQUEST_URI']);
return $scriptFolder;
function SendAdminIntimationEmail(&$formvars)
return false;
$mailer->Subject = "New registration: ".$formvars['name'];
"Name: ".$formvars['name']."\r\n".
"Email address: ".$formvars['email']."\r\n".
"UserName: ".$formvars['username'];
return false;
return true;
function SaveToDatabase(&$formvars)
return false;
if(!$this->Ensuretable())
return false;
if(!$this->IsFieldUnique($formvars,'email'))
$this->HandleError("This email is already registered");
return false;
if(!$this->IsFieldUnique($formvars,'username'))
$this->HandleError("This UserName is already used. Please try another username");
return false;
if(!$this->InsertIntoDB($formvars))
$this->HandleError("Inserting to Database failed!");
return false;
return true;
function IsFieldUnique($formvars,$fieldname)
$field_val = $this->SanitizeForSQL($formvars[$fieldname]);
$qry = "select username from $this->tablename where $fieldname='".$field_val."'";
if($result && mysql_num_rows($result) > 0)
return false;
return true;
function DBLogin()
$this->connection = mysql_connect($this->db_host,$this->username,$this->pwd);
if(!$this->connection)
$this->HandleDBError("Database Login failed! Please make sure that the DB login credentials provided are correct");
return false;
if(!mysql_select_db($this->database, $this->connection))
$this->HandleDBError('Failed to select database: '.$this->database.' Please make sure that the database name provided is correct');
return false;
if(!mysql_query("SET NAMES 'UTF8'",$this->connection))
$this->HandleDBError('Error setting utf8 encoding');
return false;
return true;
function Ensuretable()
$result = mysql_query("SHOW COLUMNS FROM $this->tablename");
return $this->CreateTable();
return true;
function CreateTable()
$qry = "Create Table $this->tablename (".
"id_user INT NOT NULL AUTO_INCREMENT ,".
"name VARCHAR( 128 ) NOT NULL ,".
"email VARCHAR( 64 ) NOT NULL ,".
"phone_number VARCHAR( 16 ) NOT NULL ,".
"username VARCHAR( 16 ) NOT NULL ,".
"password VARCHAR( 32 ) NOT NULL ,".
"confirmcode VARCHAR(32) ,".
"PRIMARY KEY ( id_user )".
if(!mysql_query($qry,$this->connection))
$this->HandleDBError("Error creating the table \nquery was\n $qry");
return false;
return true;
function InsertIntoDB(&$formvars)
$confirmcode = $this->MakeConfirmationMd5($formvars['email']);
$formvars['confirmcode'] = $confirmcode;
$insert_query = 'insert into '.$this->tablename.'(
name,
email,
username,
password,
confirmcode
values
"' . $this->SanitizeForSQL($formvars['name']) . '",
"' . $this->SanitizeForSQL($formvars['email']) . '",
"' . $this->SanitizeForSQL($formvars['username']) . '",
"' . md5($formvars['password']) . '",
"' . $confirmcode . '"
if(!mysql_query( $insert_query ,$this->connection))
$this->HandleDBError("Error inserting data to the table\nquery:$insert_query");
return false;
} $url = "http://(localhosts:9657)/rest/createUser.view?u=(admin)&p=(123hell123)&v=1.9.5&c=remoteregister&username=". $this->SanitizeForSQL($formvars['username']) ."&password=". ($formvars['password']) ."&email=". $this->SanitizeForSQL($formvars['email']) ."&settingsRole=true&streamRole=true&jukeboxRole=false&downloadRole=false&uploadRole=false&playlistRole=true&coverartRole=false&commentRole=false&podcastRole=false&shareRole=true&searchRole=true&groupID=4";
$curl = curl_init();
curl_setopt($curl, CURLOPT_URL, $url);
curl_exec($curl);
curl_close($curl);
return true;
function MakeConfirmationMd5($email)
$randno1 = rand();
$randno2 = rand();
return md5($email.$this->rand_key.$randno1.''.$randno2);
function SanitizeForSQL($str)
if( function_exists( "mysql_real_escape_string" ) )
$ret_str = mysql_real_escape_string( $str );
else
$ret_str = addslashes( $str );
return $ret_str;
Sanitize() function removes any potential threat from the
data submitted. Prevents email injections or any other hacker attempts.
if $remove_nl is true, newline chracters are removed from the input.
function Sanitize($str,$remove_nl=true)
$str = $this->StripSlashes($str);
if($remove_nl)
$injections = array('/(\n+)/i',
'/(\r+)/i',
'/(\t+)/i',
'/(%0A+)/i',
'/(%0D+)/i',
'/(%08+)/i',
'/(%09+)/i'
$str = preg_replace($injections,'',$str);
return $str;
function StripSlashes($str)
if(get_magic_quotes_gpc())
$str = stripslashes($str);
return $str;
2jmans
Postby gurutech » Sun Oct 06, 2013 3:22 am
Try using the internal IP address, or actual hostname of the computer (not "localhost"). Also, if you can, don't use the :port# - that's probably the : that the error is referring to.
gurutech
Postby 2jmans » Sun Oct 06, 2013 4:31 am
Ok I found the problem I deleted 2 things that were vital the "$" before localhost and the ";" after it.. I guess it had to do with closing part of the line the code or something... idk.. I also to keep the port number since eventually I will open this to the internet and port 80 is blocked by my isp, I just removed the ":" and put in localhost9657 instead of localhost:9657 I guess the colon messes with the code :P Anyways Im into another issue the database won't connect $this->connection = mysql_connect($localhost9657->db_host,$root->username,$****->pwd);
2jmans
Postby 2jmans » Sun Oct 06, 2013 10:08 pm
$this->connection = mysql_connect($localhost9657->db_host,$root->username,$****->pwd); is the db_host part the name of the data base or is it reserved for the computer name I was also unsure of what to put in $this -> connection part.. Arg this is so confusing =(...
(EDIT)
Also it's vital I use a different port b.c my isp blocks incoming connections to the default port 80 here's the login error on the script Failed to select database: testdb Please make sure that the database name provided is correct
mysqlerror:
2jmans
Postby gurutech » Mon Oct 07, 2013 2:21 am
MySQL uses a different port completely. Just use "localhost" and it should work.
gurutech
