Offline LastFm Scrobbling - on Mobile apps
Re: Offline LastFm Scrobbling - on Mobile apps
Postby rubbersoul » Sat Nov 09, 2013 2:28 pm
i believe dsub does exactly this.
rubbersoul
Postby daneren2005 » Sat Nov 09, 2013 6:11 pm
Well sort of. It syncs the scribbles when the client goes back online, not when the server goes back online. That is a important distinction
Sent from my HTC One X using Tapatalk
Postby rubbersoul » Fri Nov 15, 2013 1:26 am
There are definitely other improvements in the DSub app beyond this. It also is actively developed unlike the Subsonic branded app which tends to get a major update once in a blue moon. I highly suggest buying it for the updates, but if you just want to see what it's like the app is available for free on this forum i believe.
rubbersoul
Postby daneren2005 » Tue Jan 14, 2014 3:18 pm
Right now the offline scrobble works by saving the scrobbles to a file, and then trying to sync all of those changes when you go back into online mode. While I didn't actually test that I could go a week of offline mode changes, I don't see any reason why it wouldn't work. Also, I could have sworn I set it up to save failed scrobbles to try again later. If at first you go into online mode and and the server is still off, can you try toggling offline mode on/back off and see if it tries again?
