Integration with iTunes
Postby HalBup » Fri Dec 06, 2013 8:18 am
Hye,
Any chance for Subsonic to read iTunes Library.xml ?
So no need anymore to choose folder and so on ...
HalBup
Re: Integration with iTunes
Postby gurutech » Fri Dec 06, 2013 4:30 pm
Not sure if this can be implemented, but I've been creating "genius" playlists in iTunes and then exporting them to *.m3u8 files and converting them into a format that Madsonic can read (basically changing the paths of where the files are located in relation to the media folders within Madsonic), and it works fine.
I posted a FAQ/Tutorial about this some time ago, either here or on the Madsonic forums. If I can find it, I'll repost.
gurutech
