gurutech wrote:It should be more clear, but if you divide the number you see by 8, you should get a more realistic number.
daneren2005 wrote:It might be doing something that it is not supposed to be doing, but the kpbs you put is a quality limit, not a bandwidth limit (over time they are rougly the same though). It probably is just a buffering thing. If you let it go for a minute it should calm down as it reaches a buffer limit.
