[Android] Download higher bitrate if better connection
Postby themad » Sun Mar 30, 2014 5:21 pm
I needed subsonic for Android to download a higher bitrate file if better internet connection is available.
For example:
I haven download a music file via mobile network (for example 80k). Then I connect to WiFi and I want to listen the same track but in higher bitrate (since WiFi is available and in settings I have chosen higher bitrate for WiFi connection).
I have written a patch to do so. Basically it adds bitrate to filenameand If you change settings to higher bitrate or if connect to a network defined as higher bitrate, the cached file will be removed and a new one will be downloaded.
If you are on lower bitrate connection it will play highest bitrate available in cache (there should usually be only one same track in cache).
I hope you will considered applying the patch in newer version of Subsonic for Android.
@@ -22,2 +22,3 @@ import java.io.File;
import java.io.FileOutputStream;
+import java.io.FilenameFilter;
import java.io.IOException;
@@ -25,2 +26,4 @@ import java.io.InputStream;
import java.io.OutputStream;
+import java.util.regex.Matcher;
+import java.util.regex.Pattern;
@@ -59,2 +62,3 @@ public class DownloadFile {
     private int bitRate;
+    private int checkIfHigherBitrateIsAvailable;
@@ -67,4 +71,15 @@ public class DownloadFile {
                 "." + bitRate + ".partial." + FileUtil.getExtension(saveFile.getName()));
-        completeFile = new File(saveFile.getParent(), FileUtil.getBaseName(saveFile.getName()) +
-                ".complete." + FileUtil.getExtension(saveFile.getName()));
+        int availableBitrate = checkIfHigherBitrateIsAvailable();
+        if(availableBitrate >= bitRate || availableBitrate == 0)
+               bitRate = availableBitrate;
+        else if(availableBitrate != -1)
+               Util.delete(new File(saveFile.getParent(), FileUtil.getBaseName(saveFile.getName()) + "." + availableBitrate +
+                    ".complete." + FileUtil.getExtension(saveFile.getName())));
+       completeFile = new File(saveFile.getParent(), FileUtil.getBaseName(saveFile.getName()) + "." + bitRate +
+            ".complete." + FileUtil.getExtension(saveFile.getName()));
         mediaStoreService = new MediaStoreService(context);
@@ -76,2 +91,43 @@ public class DownloadFile {
+    private int checkIfHigherBitrateIsAvailable()
+       int bestBitrate=-1;
+       if(saveFile.getParentFile().exists())
+               File filePath = new File( saveFile.getParent() );
+               String[] list;
+               list = filePath.list(new DirFilter(FileUtil.getBaseName(saveFile.getName()) + ".+[0-9]*\\.complete\\." + FileUtil.getExtension(saveFile.getName())));
+               Pattern bitRatePattern = Pattern.compile("([0-9]*)\\.complete\\." + FileUtil.getExtension(saveFile.getName()));
+               Matcher m;
+               int curBitrate;
+               for (int i = 0; i < list.length; i++)
+                       m = bitRatePattern.matcher(list[i]);
+                       m.find();
+                       curBitrate = Integer.parseInt(m.group(1));
+                       if(curBitrate >bestBitrate)
+                               bestBitrate = curBitrate;
+                       else if(curBitrate == 0)
+                               return 0;
+               return bestBitrate;
+ class DirFilter implements FilenameFilter {
+         private Pattern pattern;
+         public DirFilter(String reg) {
+           pattern = Pattern.compile(reg);
+           @Override
+         public boolean accept(File dir, String name) {
+           // Strip path information, search for regex:
+           return pattern.matcher(new File(name).getName()).matches();
themad
