Select songs to be cached on mobile phone via webinterface
Postby windaishi » Mon Apr 14, 2014 8:11 pm
maybe it is possible to add a functionality, so that you can select the songs which should be synced (permanently cached) to phone directly in the webinterface. That would make the synchronising much easier.
greets
windaishi
Re: Select songs to be cached on mobile phone via webinterfa
Postby Byronnnn » Fri Apr 18, 2014 4:21 pm
Using Dsub on Android, you can setup playlist that will stay in sync and cache new music. So you could have a playlist of music to cache, and then set that up as a synced playlist. Im not sure if any other app has that. On iOS, you could do a similar thing with the playlist, you would just have to re-cache the playlist (which in turn would cache only what is not already cached). Not exactly want you wanted, but an easy workaround.
Byronnnn
