Bit rate option in 5.0 Beta
Postby tmoran000 » Fri Jun 13, 2014 1:02 pm
Although I love the option to drag the bar now to seek however the bitrate drop down option for movies was a great option that was removed from 5.0 Beta. It was used primarily by folks using my site with slower connections.
Are you able to add the bit rate selection back while keeping the drag bar seek option instead of the timer drop down?
thanks
tmoran000
Re: Bit rate option in 5.0 Beta
Postby rhall42 » Thu Jul 31, 2014 3:23 pm
I agree.. I love/need the bitrate option as well.. That was a very nice option in 4.9 and it would be great if it was still available in 5.0(beta). I had to remove the 5.0(beta) and return to 4.9 because this was not available.
-R
rhall42
