Sort Order Bug - why hasn't this been fixed?
Postby rwinters101st » Sat Aug 16, 2014 9:33 pm
I've been a paid user for a few years now. Subsonic is awesome, but I CAN'T STAND having my folders not show up in alphabetical order. Is there any way around this? My directory structure is
X:\Music\A\Artist\Album\Song
You will see in this screenshot we have two different sorts going on. This looks like a bug and not how it's supposed to function as my file system is not the issue. If you look at the two images, you'll see that Subsonic seems to split the list in two different sorts. It starts with the wrong sort, but half way down you'll find that the correct sort begins with 'A Guitar Supreme' folder which should be at the top. It's like it's sorting two different lists and putting them in the wrong order.
Here's the file system in WIndows. You can see it's just alphabetical order and sorted correctly. SubSonic should sort this identically if it's not using tags to determine sort order.
Anyone else figured out a work-around? I'll gladly write the code to fix it, just show me the repo. ;)
rwinters101st
