Subtitle picker
Subtitle picker
Postby nabab » Thu Aug 28, 2014 11:44 pm
In the folders where our video files are located sits a few subtitles for each vid, as our little group comes from different cultures.
Today it seems that a single file with the exact same name as the video but with an srt extension is detected by Subsonic, and allows to turn on/off the subtitles display.
It would be really cool to be able to choose between different files (with for example the country code stuck between the file name and the extension as it is commonly done).
Thanks for your great work!
nabab
Re: Subtitle picker
Postby jojodu31 » Mon Sep 29, 2014 9:05 am
you can use the subtitles with an SRT file really ? Can you tell us how, I've been waiting for this feature for a long time...
Thanks for sharing ;)
jojodu31
Re: Subtitle picker
Postby nabab » Sun Oct 05, 2014 10:14 pm
Hi, apologies: in fact I made a modification, I can't remember if it was with JangJong's plugin:
http://lime-technology.com/forum/index.php?topic=21356
Or with jwPlayer mod:
viewtopic.php?p=21941
But got subs like this... Sorry if I made you hope for an out-of-the-box solution...
nabab
