Keep Playlists Regardless if Media Found
Postby jps2041 » Wed Sep 24, 2014 4:51 pm
If for some reason my files gets moved, then any reference to those songs in any playlist will get removed. I would much prefer to keep the entire playlist in tact and have it show "file not found" at the very least.
This way I can see which files are not found and rebuild it manually at the very least, instead of just having all my playlists wiped out.
What I tend to do is pour all my new music into an unsorted directory and then the files get moved upon sorting, I would love to be able to keep my playlists in tact during this process.
jps2041
Re: Keep Playlists Regardless if Media Found
Postby acroyear » Fri Sep 26, 2014 4:03 pm
This is also a problem if your hard drive is remote on your LAN and has a problem: an automatic scan will basically wipe out all files and in doing so, wipe out the playlists which will then need to be reconstructed after a later successful scan.
Joe Shelby
http://subfiresuite.com/
http://subfireplayer.net/
acroyear
Postby acroyear » Mon Mar 09, 2015 3:17 am
This appears to no longer be an issue as of 5.0. I was having the same problem, and now I know longer do.
The only way to wipe the playlists when the file/folders are 'empty' (or have been significantly changed) is to click the "Clean Up Database" option.
Joe Shelby
acroyear
