Play flac direct, no transcoding to mp3
Postby daniell » Sun Jan 11, 2015 6:06 pm
Could be nice to be able to play in higher quality as flac, wav.. etc.. ??
Would be fantastic to have an option to choose higher quality formats to play, without converting to mp3..
Also alternative an option to choose output to a DA Converter from different output source etc. optic, HDMI, COAX for more pro result :-)
Thanks. Dan
Supermicro Intel(R) Core(TM) i7-3555LE CPU @ 2.50GHz, 4 cores 8gb ram
CentOS Linux 6.6 Server, jetty-6.1.x, java 1.7.0_71, Linux (143,2 MB / 437,5 MB) Subsonic 5.1
Supermicro Intel® Atom™ D510 4gb ram
Sophos Security Gateway UTM /v9
daniell
Re: Play flac direct, no decoding to mp3
Postby mitrailer » Mon Jan 12, 2015 4:46 pm
You can remove the transcoding from flac to mp3 in: settings->transcoding. Removing the transcoding will stream the flacs directly.
mitrailer
Postby daniell » Mon Jan 12, 2015 5:40 pm
Am not sure if it that easy, one will need a direct codec to read and play the flac,wav, etc. and ffmpeg is not enough or good enough.. !!
daniell
Postby jayw6541 » Wed Jan 21, 2015 1:45 am
mitrailer wrote:You can remove the transcoding from flac to mp3 in: settings->transcoding. Removing the transcoding will stream the flacs directly.
This option does not work in the web player at all and that's where I need it most at this point. If it did I would be reripping all my audio to flac. I need a single format that works across all methods of playback. I prefer Flac but Opus would do but for now all I get is mp3. Yes, if you stream to a mobile client like Dsub flac will work fine but using the webplayer is a no go. I have complained of this for some time and no one has listened. using trancoders SUCK!
jayw6541
Postby mitrailer » Wed Jan 21, 2015 3:04 am
Oh, I had no idea. But, I believe Sindre is planning to use an HTML5 player in the future (dunno when), maybe this solve your problem
mitrailer
Re: Play flac direct, no transcoding to mp3
Postby crazylegs » Wed Jan 28, 2015 11:45 pm
yes yes please i second this feature..!!! or at least be able to remove transcoding for certain user account. That way i can create a user account for lossless listening and transcoded for other family members..
crazylegs
Postby daniell » Thu Jan 29, 2015 4:45 pm
I am actually looking into "Audiophile Linux" at the moment. Since Subsonic is not able to play direct high quality formats to my home Stereo.
This is totally free. It has a LOT of features, like, built in different DAK drivers, players, just to mention a few.
Some nice features here :), maybe something Sindre should aim for with Subsonic in future.
I would believe there is a huge market for quality system/player/streaming, in future when more and more CD is disappearing from market/shops, and people buying high quality music online .. :)
Dan
daniell
Postby jarome » Fri Feb 20, 2015 4:32 pm
crazylegs wrote:yes yes please i second this feature..!!! or at least be able to remove transcoding for certain user account. That way i can create a user account for lossless listening and transcoded for other family members..
The opposite case is needed also. I have a friend with severely restricted bandwidth, and it would be nice to let him throttle his transcoding to, say 128kpbs mp3.
jarome
Postby Tichau » Tue Mar 03, 2015 4:26 pm
+1 ! I also want to play flac from the web interface. It 'll be great!
Tichau
Postby daniell » Fri Dec 11, 2015 9:43 am
Still no suggestions or fixes for this to play FLAC WMA direct. ??
daniell
