I'd actually be willing to pay a one-time contribution for that feature!
That way people can have custom certificates in an automated, easy and secure way.
mrfloppy wrote:That way people can have custom certificates in an automated, easy and secure way.
It is not a secure way because it's automated.
DaveWut wrote:As for your question JollyOrc, use an Apache2 proxy. It will make your setup a little simpler. You won't have to change the configuration of the subsonic web server and it will allow you to centralize the management of your certificates only by using the client command line tool of Let's Encrypt.
JollyOrc wrote:DaveWut wrote:As for your question JollyOrc, use an Apache2 proxy. It will make your setup a little simpler. You won't have to change the configuration of the subsonic web server and it will allow you to centralize the management of your certificates only by using the client command line tool of Let's Encrypt.
I'm doing this with Caddyserver right now, but I run into the problem that the login.view and the settings pages somehow call localhost directly. (more wordy here: http://www.orkpiraten.de/blog/subsonic-caddy-oh-my)
Is there a way to force Subsonic to not do this?
