Change Chat Window Size/Scroll Bars Size?
Postby philospider » Thu Mar 31, 2016 2:23 am
It'd be great if we could have the ability to adjust the chat window size. Drag it to the left a little so I can read more than three words.
Or if that creates space issues, maybe wrap the text more? The chat right now is really hard to read, scrolling back and forth a lot with any sentences.
I've also found the scroll bars the smallest bit on the slim side, would it be possible to customize those? I keep missing and throwing my playlist around. I should probably cut back on the coffee, but I feel like a sharpshooter at work with this thing. 8) 8) 8)
philospider
Re: Change Chat Window Size/Scroll Bars Size?
Postby karb0n13 » Mon May 02, 2016 10:23 pm
I, too, got fed up with tiny chat on the right along with a problem of things like long links messing stuff up making it so that you had to scroll far to the right to see whole messages, so I made some modifications for myself to resolve these problems.
These changes I am listing here apply to version 6.0 (build 830afc) – April 30, 2016 and ymmv if trying to find where to apply them on different versions. Also of note is that these changes will be overwritten on the next update.
The changes that I made were to 2 files in my "C:\subsonic\jetty\830afc\webapp\WEB-INF\jsp" folder:
right.jsp (line numbers are on the left side denoted like "212:")
212:   <div id="now-playing-container" class="detail" style="max-height:115px;overflow-y:auto;overflow-x:hidden;">
221:   <table style="table-layout:fixed;max-width:500px;">
223:   <tr id="pattern" style="display:none;margin:0;padding:0 0 0.15em 0;border:0;"><td style="max-width:500px;word-wrap:break-word;display:inline-block;overflow:hidden;">
index.jsp (line numbers are on the left side denoted like "212:")
052:   width: ${model.showRight ? 540 : 0}px;
I hope this helps you with your problems.
karb0n13
